bump in road.. found out it is motor mounts...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Feb 13, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    when i gas over big bump I get a big 'CLANK' by my gas petal on my floorboard. it doesn't sound good.
    what could it be?
    I must of broken my engine mount when i went off roading last weekend. It looks like it is the left motor mount. when i apply gas with my brakes on, my engine rotates toward the right and literally lifts up like 6 inches. if i hit a bump in the road it must be shaking around in there...
    how dificult of a job is it to replace one of those bastards and if i am at it i might as well replace the right and tranny mount too?
    baja surf nazi<P ID="edit"><FONT SIZE=-1>Edited by bigblue on 02/14/01 02:50 PM (server time).</FONT></P>
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: when i gas over big bump
    Do you have a lift? If not, I would guess it is the leaf springs bottoming out on the bumpstops...a good excuse to get a lift...
    90K5
  3. bigblue
    Dec 6, 2000
    658
    southern california
    no i have a 6 inch national spring lift. I don't know i felt it a little when i went wheelin this past weekend. it is like someone hitting a hammer right under my feet. it happens when the springs compress. going over bumbs in the road but only big ones. weird?
    baja surf nazi
  4. Re: when i gas over big bump
    it could be the sheet metal in your floor board flexing and popping at the bodymount. Mine does that sometimes.
  5. bigblue
    Dec 6, 2000
    658
    southern california
    I hope that is all. I am going to investigate it further and check underneath as soon as i get off of work.
    baja surf nazi
  6. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Re: when i gas over a big bump
    Check your engine, transmission and transfer case mounts. You could have a broken one.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  7. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    All that happens when i hit the gas over a bump is alot of tire spinning and a sore neck!
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  8. bigblue
    Dec 6, 2000
    658
    southern california
    OK so it might be a transmission, t-case, engine mount. how hard to replace those? thanks
    baja surf nazi
  9. bigblue
    Dec 6, 2000
    658
    southern california
    I posted my question up top thanks
    baja surf nazi
  10. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    As long as you have access to a cherry picker it is really not a problem to change out the mounts. I have heard the energy suspension makes great polly mounts for the motor and the trans. And you are right, you might as well change them all if they are the stockers in the truck.
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    You could also use a good size block of would and a jack from underneath. I would be more comfortable with my hands in there with a cherry picker though.
    Rene
