Bump steer ...Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Sep 15, 2001.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    OK, I put another bx on my K5 and it is really tight (no slop) no leaks etc. but since I put it in,.. the bump steer is much worse! Before the new bx. there was a little slop and No bump steer....now it seems like it's harder to keep straight on the road when there is a little wind or some minor highway bumps etc. Also everytime the tires hit a little dip the steering wheel JERKS one way or the other Does the drag link need adjusted or something else?? please help this is really frustrating. THX
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    What do you have in the way of a stabilizer? When I put the coilover on mine, I ended up with zero bump steer.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    You don't mention if your truck is lifted, but if it is, I would suggest the swaybar disconnect/correction kit from <a target="_blank" href=http://www.offroaddesign.com/catalog/swaybarkit.htm>Off Road Design</a>. Your old, sloppy gearbox may have been hiding a lot of your bumpsteer until now. Now that you have a tighter steering system, it will be much more obvious to you.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Check out my "best reply ever" out of 975 tries, I should have stopped with this one.[​IMG] (do a search for "bumpsteer" by desertduleler on 5/24/01)
    The bump steer was probably allways there, just not noticed with the old sloppy box. Also, is it lifted, has the steering arm been corrected for the lift?
    We will stand strong!
    <font color=blue>AMERICA!</font color=blue>
  5. twenty_below0
    May 16, 2001
    436
    I have a E-Z Ride 4" and Dual stabilizer, the kind where they both connect in the middle and go towards the tire on each side, the full length of the front end, and how will the sway bar disconnects, correct the bump steer, I have urethane bushing and quad shocks in the front and 33" tires...if it was just not noticable before then how can I fix this problem now??? Everything on the front end is new and tight!, THX for the help!!
    WE WILL SEARCH FIND AND DESTROY THE ENEMY!!!! GOD BLESS THE US.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Do you have a raised steering arm?
    ORD's sway bar disconnects also relocate the mounting point for the sway bar to correct for the lift...
    Rene
  7. twenty_below0
    May 16, 2001
    436
    yes everything is done correct and I have the correct steering arm!!
  8. twenty_below0
    May 16, 2001
    436
    Did a search and read twiztid's answer for the "bumpsteer" problem and his response is great so I think I can figure it out from here THX For the INFO!!!
