Bump steer Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AMorris1, Mar 9, 2001.
  1. AMorris1
    AMorris1 Registered Member
    Mar 9, 2001
    8
    Fremont, CA
    I have a 84 K5 blazer with 33 x12.5 BFG's. I just installed a 4" Procomp lift to accomidate the larger tires, and since I installed the 4" steering arm that was supposed help my steering, bump steer went from almost non existant to very noticible. I have talked with the folks down at 4WP wholesalers several different times and have gotten a different answer everytime... take the arm off, get an alignment, etc. I think an alignment is probably my next bet, but will this really fix it, or will I have to live with it to a certain extent. Anything else I might try. I installed the lift myself, so is it possible that I didn't do something right? Any helpful comments would be appreciated!
  2. zrobbinsk5
    zrobbinsk5 Registered Member
    Dec 23, 2000
    45
    Beaumont, Tx (north of houston)
    im running a 4" superlift and 33x1250 BFG muds also and there is a bit of bumpsteer to a certain extent, nothing severe, but im sure it would be worse without the steering arm.
  3. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    you need a steering box brace have a friend watch as you turn the wheels and be amaxed as you see the steering box move,I need to order on also so I know how it feels My wife wont even drive it right now
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did you tighten everything up with the load on it?
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    AMorris1- you're right, an alignment is your first best bet. It's not expensive, saves your tires, and you can learn alot. Find a shop you can trust, watch the alignment, and talk to the tech doing it. They will pick out any steering issues right away, and show you what's wrong. Whenever you buy a set of brand new rubber you should get an alignment. Most good tire dealers will tell you to get one.
    The ORD steering brace is an excellent idea as well- (installed before the alignment)
