bump steer update
Discussion in 'The Garage' started by chevyjeff, Oct 12, 2004.
  1. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    Installed a drop pitman arm and stock steering arm (thanks thor!) on my 4" lift an I now have almost no bumpsteer. /forums/images/graemlins/smile.gifStill have some which is normal but the steering wheel no longer jerks back and forth. Dont know why in the hell 4" lift kits come w/ the raised arm. Its about 4" taller than the stock one. Draglink length was reduced by about 1 1/2" using the drop pitman arm. Raised arm is good for a 6" lift and stock pitman arm but not for a 4" kit which they recommend it for. Oh well live and learn.
    p.s. slightly used raised steering arm for sale..
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I remember that post. Glad you got it working now /forums/images/graemlins/woot.gif
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Glad it worked for you! /forums/images/graemlins/waytogo.gif
  4. dlaw36
    dlaw36 Registered Member
    Jan 11, 2003
    71
    Did you use the 2" drop or 4" drop pitman arm?
  5. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    I used the skyjacker pt #ca-90 its about a 1 1/2" drop and was the only one I could find that was made for a 4X4 box.
  6. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I couldn't find the #ca-90, it did however show a ca-50 for a 2" drop..
    I have a bump steer problem also and this is going to be my next choice to try to eliminate it.. I hope..:crazy:
