bump steer
Discussion in 'The Garage' started by 79cheyenneblazer, Nov 8, 2004.
  1. 79cheyenneblazer
    79cheyenneblazer Registered Member
    Jul 21, 2002
    68
    Jasper,Indiana
    I got a 79 blazer 4 inch tuff country lift with the steering arm, also i put on the dual stabilizer kit and i still have bump steer. Is that normal?..all my friends have lifted chevy trucks and they don't have the problem. Both blazers i have had have done it. Just wondering if there was something i overlooked when installing?...help please!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with a 4" lift you need a drop steering arm instead of the raised steering arm, the drag link needs to be parallel with the spring.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    steering stabilizers do nothing for bumpsteer
    bumpsteer is a geometry problem
  4. 79cheyenneblazer
    Jul 21, 2002
    68
    Jasper,Indiana
    so what i am gathering is that the stock steering arm on the axle should be there, but there should be a drop pitman arm?, its not necessisarily bad, just rather annoying
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    This seems to work the best with a 4" lift.
  6. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Check the alignment, with a lift and bigger tires it can really affect bump steer. Also check for wear in the steering components, steering box, ball joints, etc. If any or all of these are worn bump steer can become a major problem.
  7. 79cheyenneblazer
    Jul 21, 2002
    68
    Jasper,Indiana
    well everything is really tight on it, and it only has 33's on it, and the lift has only been on for about 2,000 miles, didn't do it to begin with but started when the lift was put on. I am selling the blazer and I am trying to get things fixed the way I feel it should be when it will be sold.
