Bump Steer
Discussion in 'The Garage' started by fasthumpman, Oct 29, 2005.
  1. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    Is there anything I can do to reduce bump steer? I nearly broke my thumb when I hit a rut. and does anyone know how to put pictures in my post??
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Go to www.photobucket.com and sign up. Put your pictures there and then hit the [​IMG] when you post, and copy/paste the properties from photobucket into your post.
    What steering set up do you have now? Any suspension lift?
    :wink1:
  3. fasthumpman
    Oct 22, 2005
    85
    Texas
    Its a 1980 k5 with a 4 1/2 inch lift and 35's. Other than that its all stock up front.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Steering Stabilizers are made for that, I know they helped my truck with that and tire wobble. Some people will say it's from bad steering parts, but my truck had the wobble with all new steering parts...Dana parts even.
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Got a raised steering arm or drop pitman arm on it? Either of those will help, but won't eliminate the problem. Crossover steering is the true cure, but requires quite a bit of work and usually $$.
    I run the same lift up front, with a raised steering arm. Bump steer was really bad until I replaced the steering stabilizer. Much better but it is still noticable and annoying offroad.
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
