bump steer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seanmp, Jan 1, 2004.
  1. seanmp
    seanmp Registered Member
    Dec 6, 2003
    21
    I put a 4" lift on my suburban, and left the stock arm on for 2 weeks. After changing to the 4" steering arm, I have a LOT of bumpsteer/bad handling. The steering wheel was centered using the adj. coupler on the drag link, and the drag link needed a LOT of adjustment. any ideas?
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Your steering stabilizer may be shot. Its the shock looking thing on your front axle. Look at where the shaft comes out of the piston, if you see any sign of an oily substance you need a new one. If you got the cash get dual stabilizers.
  3. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    I had the same problem on my '90 Blazer after a RC 4" lift. It originally had quad shocks but the kit didn't provide them. I bought the extra shocks and put on the RC dual stablizer. Problem solved!
    Good luck. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
