Bump stop options for rear w/ 56"s & filp
Discussion in 'The Garage' started by xtrmjoe, Aug 10, 2005.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I have a shackle flip and 56" leafs with 4" lift (tc springs minus a leaf) in the rear, also longer shackles. I need to move my bumpstops down 4-6" or so any Ideas? I already have the 4.5" bumpstops ORD sells but still not even close.
    In the front with the 52"s it was easy just a piece of 2"x2" tube inbetween the mount and the stop.
  2. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    Picts or opinions.
    Does anybody even run them in the rear?
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    why??
    I run non lift 56's out back with no bumpstops.
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I've seen bump stop landing plates built into the top of the spring plate. Thus you can leave the bumpstops in their current position. Try looking at marksmark.com - he has a nice setup for the rear springs on his Dodge.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Old thread warning. I've just completed my rear 56" spring and flip conversion. Anyone out there have a working rear bump stop setup? Pics?
  6. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    They're not pretty but they work... DIY4X shackle flip with Ford 57's...
    I set it up so I hit the bumps on the tube about 1/2" before the shocks bottom out...
    Someday when I start messing with tube I'll probably make something different but for now this works. It's .250" wall tubing attached to the factory bracket (which has been relocated to line up with the axle after the 57's)...
  7. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks! I'm running rectangle tube up front to space my 2.5" poly stops down. Guess I'll take the same suggestion on the rear suspension for now. I like the ford towers and limit straps in the rear.
    You might want to cross tie or triangulate the rear towers to avoid cracking the frame though.
  8. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Those are only on there until the tube goes in and I keep an eye on them to make sure they don't have any wiggle room. :)
  9. rcamacho
    Jul 1, 2004
    1,324
    WA
    I cut down some 2x4" rectangle tube to space down my 4.5" bump stops. It was a bit too close so I trimmed the first section off the bumps and have about 2" of free clearance. My springs are nearly flat so this is about right to keep them from going negative.
