Bump stops
Discussion in 'The Garage' started by PROFESSORSK5, Apr 13, 2004.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    I have a 89 k5 with a 6" lift and 35 BFG all terrains. I think I have the stock bump stops. Does anybody know where to get them and exactly what I need? /forums/images/graemlins/k5.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Are you looking to get some to compensate for the lift?
    If so, I don't know if there are longer after-market ones available. Most people put in a spacer between the rubber bumpstop and the bracket. To know how big of a spacer you need to put in:
    1) measure how far it is from the bottom of the bumpstop to where it contacts the axle
    2) measure the amount of shock travel left (how much rod is showing)
    3) subtract value #2 from value #1 and add about an inch (to make up for the rubber compressing, etc). That's how big of a spacer you need to fabricate.
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    ORD has them. /forums/images/graemlins/thumb.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/yikes.gif
    /forums/images/graemlins/doah.gif
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Something else to considder along with heavy4x4s formula is that when your done the bumpstop should be mounted to prevent the springs from over compressing (negative arch)also.
    Over compressing your springs will ruin them over time /forums/images/graemlins/grin.gif
