bump stops
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Jul 3, 2001.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i just lifted my suburban 4". should i lower my bump stops or get new ones? can anything be damaged by not getting longer bumpstops? if i need new ones, how much are new longer stops?
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 35s, tbi350
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I would definitely get longer bumpstops or atleast lower your factory stops. I've seen 4" urethane stops as low as $50 a pair - It all depends on who you go through.
    Elvis lives!!
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  3. scrapmetal
    scrapmetal 1/2 ton status
    Jan 22, 2001
    100
    Rathdrum ,ID
  4. Grim-Reaper
    7,385
    Atlanta
    The rear is usaly not a problem but the front with larger tires will have scrub poblesm. lowering the bumps will help from really jamming a tire in. you also need to get it flexed with passenger front stuffed and check driveshaft length. Lift springs change the arc the axle cycles at and as crazy as it sounds sometimes with a 4 inch lift your front driveshaft is 2 long. If it bottoms out you can rip the transfer case right off the back of the tranny. I have seen it happen and it aint pretty.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  5. muddysub
    Jun 23, 2001
    10,452
    489
    thanks for that advise when i get new brake lines then ill try that.
    scott,
