Bumper Air Tanks Yea or Nay?
Discussion in 'The Garage' started by Dallin, Jan 25, 2006.
Should I make the bumper an air tank?
  1. Yea
    95 vote(s)
    68.3%
  2. Nay
    44 vote(s)
    31.7%
Thread Status:
Not open for further replies.
  1. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    I'm building a rear bumper. Should I make it air tight and use it for an air tank? Yea or Nay & why?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have used two rear bumpers as airtanks and it worked out great!
    I have heard some pretty funny things about it though. I had one guy claim I was driving a gernade around and other people thought a hard hit could split the bumper and cause it to blow up. Like a 100 pounds of airs going to do anything to 3/16" thick bumper material. Pretty funny stuff.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Yes I would. Will you have on-board compressor and will this be a daily driver? There shouldnt be any problems as long as you are using thick enough steel. Personally I would only have it pressurized when I go out wheeling. Wouldnt drive around town with it pressurized. Guess Im just paranoid.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    No reason not to - it would be a convienent place to have a little air on the trail.
  5. nm4x4
    nm4x4 1/2 ton status
    Nov 24, 2004
    144
    Wichita, Kansas (McConnell AFB)
    Yes,
    I made one out front and it works great. I also have the small MV-50 air comp. mounted on the inner fender under the hood. Cheap and easy, plus you will never know when you will need it! I have used it mainly to help people with flats on the side of the road. I have also had ignorant people think it is going to explode :doah: ; at most it could burst a weld and drain out.
    Long story short, DO IT!!
  6. Dallin
    Feb 12, 2003
    135
    Thanks for the input everyone. I've heard a few people say they can explode, but I can't find anyone who has seen it happen. I'm making my bumper out of 2x6 .188 wall. I think it'll hold 120 PSI just fine. I'm currently using a CO2 tank, but I'd like to get a York. I figured it would be easier to build the tank now than down the road after everything is finished. I just wanted to make sure there isn't some drawback I haven't considered.
  7. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i think those bumpers are cool , my buddy has a custom set that his dad made for him . he made his were the front bumper holds enough to air the front 2 tires and the back has enough to air the back tires . it works good on the 38's he's running. i was thinking about pay n him to make me some , anyways thought it was cool. :D
  8. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    oh yah
    oh yah i have one on the front of my truck, with a air compressor in the engine bay with a inline pressure regulator. i would go a minimum of 3/16 tho. but dont plan on raming anything cause it will probable screw it up. mine is made out of 3/8 thick- 5" O.D tubing with cross braces to the frame for added strength.
  9. Dallin
    Feb 12, 2003
    135
    The vote says 25% nay, but nobody has posted why. Post up nays, what's the reason.
  10. 91BurbDude
    91BurbDude Registered Member
    Dec 17, 2005
    16
    North Carolina
    I'm sure it would be fine. I watched the episode of MythBusters and they shot a scuba tank with a rifle to dispell the JAWS myth. No way it could explode. As soon as the bullet made the hole the air leaked out and the tank flew around like a missle. Of course they put the tank and gun inside a metal storage container and remote triggered the gun. Once a hole or rupture occures the air blasts out. Just like shaking a coke bottle to build up pressure and then opening the cap thus producing a hole for the pressure to release.
  11. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    :shame: I heard that bumpers as air tanks may not be legal as far as DOT is concerned :deal: , but how would they check and how often. I'd check with the DOT of your state just to be sure.
    I don't have any problems with them, but I would deffinately protect the inlet/outlet/gauge area. Put a halo around them so they won't get knocked off in event of doing something stupid:doah: .
  12. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    do it. it will not blow up or anything like that. I have a Toyota Pu on air bags with the tank under the bed hit it on all kinds of stuff no problems and its at 150 psi. My Friends have run around with nitrogen tanks at 2400 psi.you will be fine. do you have a compressor yet? If you need any help let me now
  13. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    think about it, if the tank is pressureized, it will be harder to dent and damage, the psi is not large enough to explode by a puncture, if ya want to see what happens, take a old propane tank, fill it with air to the psi desired, and go shoot it with a nice size rifle, make sure ya are away from anythgin, i aint exactualy sure how the added pressure will affect the penetration, as for shooting steel, i shoot 1" plate plingers out on the farm and the military guns go through 3/4" and its safe.. about 100 yrds...
    as for a compresor, couldnt ya use a a/c compressor, that is if ya want to...
  14. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    You can use an a/c compressor but they are oiled by the refrigerant unless of course you get a york !
  15. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I had one
    My 74 K20 came with a "air tank bumper" when I got it..it was homebuilt from schedule 40 plumbing pipe about 5" in diameter!--I took it off to put a plow frame on,and gave it to a friend..he put it on his 86 K20,and the front end drooped almost 3"..I think my plow weighed less!..
    Mine was plumbed up to the OEM GM air conditioner pump(the big log style)..it was working when I first bought the truck,but after using it to run an impact wrench to take all 4 tires off,it seized and smoked the belt off it!..It pumped up to 125 psi in no time while it was working,but I guess the pump starved for oil..:doah:
    I wasn't concerned because I did not plan on keeping the setup anyway..but it would be a nice thing for a trail truck to have..I see nothing really "dangerous" about it..it would go "POW" if it got hit in a crash..I doubt any serious damage would be done..only if a peice of shrapnel flew and hit someone..very unlikely IMO..:crazy:
  16. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    After seeing Grim's airtank rocksliders hold up I wouldn't worry about a bumper. Just remember to add a drain, you can count on condensation.
  17. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I say nay. It is illegal in many areas. And without a drain, it will rust up inside. I don't know if the puncture-explosion thing is a possibility.
  18. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    stainless steel.....or aluminum
    now that would be a nice bumper
  19. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    No!
    I vote No.
    Unless you are well versed in ASTM Pressure Vessel Design & Welding practices I wouldn't do it.
    Ever think that there is a reason that you air compressor's tank has rounded ends? Are you planning on making the bumper the same way? Flat ends put huge stresses on the welds holding them on. I can go on and on and on, but I'll stop here.
    Just b/c it works doesn't mean it's safe.
  20. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I said nay. Reason being there is alot of unused space you can put a propper air tank on k5's and trucks. The you wouldn't have to worry about the drain plug getting knocked off when you're wheeling.
    Just a thought.
Thread Status:
