Bumper/winch clearance?
Discussion in 'The Garage' started by johnathan, Feb 1, 2007.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I have live work project in my welding class to do so I'm gonna build some bumpers for the K5.How much clearance do I need behind the front plate to mount a winch?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    What winch are you planning on?
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'm not sure yet.I wanted to get the winch before starting the bumper,but thats not gonna happen.I could probably get the dimensions for the winch,but I was'nt sure how far the fairlead needs to be in front of it.I've never mounted a winch bfore so I don't know where to start.I wanted to keep the bumper as tight as possible.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    So mount the winch underneath the radiator.
    You can then run some tube or Rectangle out to the ends and make it look however you want and it is real close. The only problem with this type of mounting is you have to have a remote solenoid pack you can't use one of the Warns that has the solenoids on the winch.
    Ira
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    If you go to warns site you can get pictures with mounting diamensions on them.
  6. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    8.5-9" depth will cover most winches!
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    This is entire mounting surface (base), not the distance between the winch face and the fairlead mounting surface.
    Click Here see if this helps
