bumper
Discussion in 'The Garage' started by screamer*145, Jul 26, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    ok i am building a tube bumper and want to had to hitch but since i am new to /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif, what size squar tubing do i use also pic of your bumpers would great to get some ideers!
    thanks!
  2. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    someone, anyone know!
    /forums/images/graemlins/dunno.gif
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    For the reciever 2" is the standard IIRC /forums/images/graemlins/waytogo.gif
  4. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Are you wanting to know what size square tubing to use on the bumper to slide the hitch in to? The piece you slide in is 2", so the bumper needs an inside measurement of a little more than 2". 2 1/2" with 1/4" wall will not work. If you have any trailer sales places or truck accesory or camper shell places near you, check with them because they might have a piece that is the exact size and comes with the ring around the end of it for extra strenght. All you do is weld it in. The piece they sell will look like what is in a factory made receiver hitch.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My local tractor supply sells just the reciever, it is about 1 foot long so you can just trim it where you want it, also reciever tubing is not the same as regular steel tubing the reciever tubing doesnt have the weld seam on the inside of the tube.
    -Chris
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Try the local farm tractor supply you can buy the receiver sections for about $10 pre drilled and ready to weld in.
    If you have steel at your disposal 2.5" 3/16 wall and the slide in parts should be 2" 3/16
    Front side
    backside
    the place here had 8", 12" and 18" receiver hitch sections ($9 up to about $21) I used two 8" pieces in the front and rear bumpers I made
    (I never miss a chance to my pics /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/whistling.gif)
