bumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5texan, Aug 1, 2001.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    i am building a front bumper similiar to ORDs green blazer and my question is should i use pipe or tubing and what thickness
    thanks
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You should use .125 wall tubing at a minimum. Pipe is typically weaker, and doesn't weld as well.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Yea what he said. Eric
    Lost? i'm not lost i'm just disorienated
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  4. I would go with something a bit thicker. Closer to 3/16 or 1/4 but thats just me.
    Also I dont think the tubes look good either, and the boxed type seem to have more versatility as far as mounting stuff on them.
    Damn I need to learn how to use my welder!![​IMG]
    (90 Jimmy 350 TBI, 14 FF/10 bolt, 4.56, tires ??
    (ftn96)
  5. k5texan
    Aug 1, 2001
    119
    Flint, TX
    i was figuring 3/16 at the most because if i hit something hard enough i rather the bumper bend than the frame. the ORD blazer has 2X.120 tubing for the bumper and the sliders
  6. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Yah, pipe wont bend it will break, and it doesnt weld well, UH-OH!!!! I have mine whole front Exo Cage built out of pie and it has taken some VERY serious pounding and had no problems, and it welded fine. I have seen two rigs roll with the same pipe I have and had no issues. YOu may not be able to enter NASCAR but I think a front bumper will be fine. Just my .02
    autotronixcaraudio.com
  7. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    Tubing and use .120 wall 2" -3" diameter mild steel it does not need to be any heavier for a bumper. Although if you plan to bend it at all I would go up one wall thickness to .156 wall. Just my $.02.
    J:(P it's what's for dinner!
