BUMPERS
Discussion in 'The Garage' started by 74beater, Jan 9, 2003.
  1. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    LAST WEEKEND AT THE SLAB, A LEDGE DECIDED IT WANTED TO MOVE MY BUMPER..IT'S WAS WELDED IN BUT I HAD FORGOTTEN TO BOLT IT UP...SO THE TRIED TO PEEL IT OFF..LAST NIGHT I FINISHED IT OFF, AND CUT 3IN OFF OF THE FRAME. THE IDEA IS TO REMOUNT IT CLOSER TO THE BODY....BUT WHILE I HAVE THE BUMPER OFF I THOUGHT I WOULD RAISE THE TANK, ANY IDEAS ARE WELCOMED...THANKS YALL
    ALL HAIL THE ALMIGHTY SAWZALL /forums/images/graemlins/k5.gif /forums/images/graemlins/rotfl.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm planning on raising my tank next month. Basically the idea is to remove the two crossmembers that hold the tank and space them up the desired amount. I have a three inch body lift and it looks like I could raise the tank up about 3.5" total. There will be some notching of the crossmembers that will need to be done so that it will fit between the frame in its higher location. I've got some pics of a guys setup. I'll try to find them.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i'm looking into this as well when i do my tank swap. it doesn't look to be that hard to do. let me know if you do it and what issues you run into.
    btw...it was great wheeling with you!
  4. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I'm getting ready to do this too. My 31 gallon tank has been crushed to a 26 gallon tank /forums/images/graemlins/blush.gif so it's time to replace it! The two crossmembers and the upper frame rail edges have to be trimmed since they wrap over the tank, then new supports fabbed up higher. It's easier to do if you use a poly tank since it doesn't have the weld seam all the way around, that can get in the way if you raise the tank more than 2 inches or so.
  5. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    THAT WAS A GOOD TIME BROTHER, CANT WAIT TILL THE NEXT RUN..WHAT TIME DID YALL GET OUT OF THERE..
  6. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    we finally hit the road about dark, i got home around 6 or so.
