bumpsteer after steering arm install? I think.
Discussion in 'The Garage' started by cochino12, Aug 21, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    ok I have been running a 4" lift for about a month and have had no steering issues using the stock steering arm. Well I finally got around to installing a raised steering arm and now I have a bump steer kind of pull about 30mph. WTF did I do wrong? I used a BIG hammer to pound the number that are stamped on the original arm (Which I read on a thread here) and it came off without a lot of hassle. Any ideas? Thanks
    Adam
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    a steering arm should not have any effect on your axle alignment. i would look to see if you damaged your balljoints while removing the old arm.
    how level to the ground is the drag link? if it is level, you should not experience a lot of bump steer. but if you installed shims between the axle and the springs that will not help your situation.
  3. cochino12
    Dec 23, 2003
    563
    Parker, Co
    As far as the drag link goes it is pretty level, a whole lot more level than it was before the new arm. Dumb question here, how do I tell if the ball joint is bad?
  4. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Adam,
    I installed a 4" lift and used the stock steering arm for a while also. I then installed the one for a 4" lift (Part # GM440 in think) and it seemed to me to be doing as you discribed.
    I noticed a few things; first was that the new steering arm was longer. I also notice that I could no longer make as sharp left hand turns.
    I adjusted my draglink and all seems fine.
    Apparently I got use to the bump steer issue because I don't feel it anymore. It may have just been that we were use to the operation of the stock one. /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/peace.gif
  5. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    You need to have the draglink parellel to the spring, not the ground.
  6. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    could you explain your reasoning, that doesnt make sense to me.
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    All I can add, is that people who have had this problem, have corrected it by making the draglink parellel to the spring, and not the ground.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    You need to have the correct angle in the draglink (with respect to the spring) so that as the spring compresses (and the axle therefore moves rearward) it doesn't turn the tire.
    It seems that many raised steering arms are actually too tall for a regular 4" lift.
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
  10. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Ok here is a pic of the draglink, thanks for the info everyone
  11. backcountry
    May 27, 2004
    916
    Looks just like my setup! Looks inline to me!
