Bumpstop brace stupid question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alec78, Sep 12, 2004.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    This thing is located right below the starter, making access to it darn near impossible. It also makes three bumpstops on the passanger side. Is it really needed? IF the suspension could compress enough, it would "land" (maybe hit is a better word) on a flange on the pumpkin right next to the pinion.
    I'm thinking either /forums/images/graemlins/hack.gif or /forums/images/graemlins/weld.gif ...Thoughts???
  2. dyeager535
    26,982
    191
    I pulled mine off.
    Assuming since there is already a stop for the axle tube, this one is to keep the pinion from rotating up when the axle is stuffed up. Sounds good anyway. /forums/images/graemlins/smile.gif
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I've often wondered what the hell they were there for as well. /forums/images/graemlins/ears.gif One of mine fell off the other day. Maybe it was somethin to help with the stock spring setup? I dunno.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    With lift springs the stock bumpstops are pretty much useless. As far as I can tell the original design was for the rear most stop to touch the springs first, this 'raised' the spring rate during heavy hits. The front most stop was the normal bottom out stop to keep the axle out of the oil pan. The single bumpstop over the diff kept the diff from kicking up into the oil pan/starter area. Kinda goofey huh.
  5. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i had to pull it off my rig to fit the hedders...
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    GM added that bump stop in later years, to serve but one purpose. If you skyed a stock truck just right and then landed hard on the right front, it would shove the axle up high enough to snap the starter right off the block. /forums/images/graemlins/eek.gif
  7. dyeager535
    26,982
    191
    Note to self: no Dukes of Hazzard jumps.
  8. justhorsinaround
    Sep 16, 2003
    6,798
    Don't you mean Fall Guy jumps?
  9. alec78
    Aug 5, 2002
    358
    Washington
    SWEET!!! I think I'll remove it!!! /forums/images/graemlins/peace.gif
    This ought to remove about 2 pounds...I'll add some stickers...a spoiler...blink bling wheels and show them Ricers a thing or two!!! Headline reads, "Diesel Blazer beats Riced Car In Street Race, Sony offers $$$ for Mini Series"
