Bunch of parts Axles, engines, trannies and more!!!
Discussion in 'General Parts for Sale' started by afroman006, Jun 4, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Ok I got all the engines pulled from the CUCV's and here's what I have.
    3 6.2L diesels. All are missing intakes and all are missing various parts but all have rotating assembly, heads, and timing components. Make offers on whatever you want.
    2 TH400 4x4 Cores. Do not know if they work or not, came out of non-running trucks. $50 apiece
    2WD TH400. Works and shifts great came out of truck w/ blown engine. $150
    292 I6. Complete sans accesory brackets. Make offer.
    2WD SM465. Works and shifts great. $150
    NP208. Works. $100
    14 bolt FF 1 ton housing. Make offer.
    1 Ton 2WD spindles. Super beefy and use Bendix calipers same as D60. Make offer.
    4" lift front springs. I think they're rough country. New ORD poly bushings. $75
    3/4 Ton axles. 10 Bolt front 14 bolt SF rear. 3.73 gears and posi rear. $400 together
    14 bolt SF. 4.11 gears and open carrier. Fairly new brakes. $100
    84 chevy front clip. Light blue little rust on bottom of fenders. Make offer.
    84 chevy cab, frame and bed. Make offer (will seperate)
    4x4 brackets (everything needed to do 4x4 conversion. $100
    ***New additions***
    3 TH400 dust covers. $20 apiece
    Stock 8 lug 16" steel wheels. However many you want. $10 apiece
    Stock 4x4 pitman arm. $10
    Stock 10 bolt/ D44 steering arm. $10
    4" tapered rear lift blocks. $20
    2 Upper "A" arms for 3/4 ton 2WD. Driver's and passenger side. Make offer
    Th400 to NP208 adapter. $20
    D60 calipers. Might work but not sure. Can be used as cores or rebuilt. $10
    Shocks for 4" lift. front 2 are Pro-comp, rears are rancho. All in great condition. $40
    Stock 3/4 ton front springs and shackles. Awsome condition. 3 leaves. $50
    Rear driveshafts out of 2wd LWB pickup and 2WD crewcab pickup. Both are the type with the slipyoke and center support bearing. $30 apiece.
    Front driveshaft out of CUCV. Th400/NP208 to D60 length. Rusty, need rebuild. Has flange mount and C/V joint. $30
    More to come, reply here or PM me if interested in anything. I can deliver larger items for cost of gas or you can pick up. Thx
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    Re: Many CUCV & 6.2L diesel & 3/4 ton parts F/S!!!!
    I am interested in one of the turbo 400 cases and if you have the adapter to go from the 400 to a 208 that would rock too....Jason
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    any chance you have good ebrake cables off of this?
  4. afroman006
    Aug 21, 2002
    2,876
    TTT
  5. afroman006
    Aug 21, 2002
    2,876
    TTT...again...
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    ok asking another one here, how about the pinion yoke off the 14 bolt? is it still there and if it's a 1350 ujoint are you willing to pull it?
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll call dibs on one of these as I see someone may already have called for.
    Is this a 208 style tranny?
    Thanks,
    John
  8. afroman006
    Aug 21, 2002
    2,876
    Sorry, the pinion is already gone. Ok, you got the last 4x4 tranny. I need to figure out how to ship though, gimme a few days. Thx
  9. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    How much for the 14 bolt SF w/ 3.73 gears? I only need the rear.. and is it a 6 lug bolt pattern or 8?
