Burb body on pickup frame?
Discussion in '1936-Present Suburban' started by u2slow, Mar 15, 2003.
  1. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I know its not a direct fit, but has anyone put a Burb on a pickup frame? I figure about a 3" body lift will make it fit - or am I missing something?
    I'm only asking since I have a spare 1-ton frame, and its a pity to throw one of these away.
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    there's a 10 inch difference in the wheelbase of a pickup and a suburban. longbed pickup is 119.5, and suburban is 129.5 ( or thats what I've read/been told) both vehicles are about the same length, but the rear axle lives farther back on the sub.
    -Rich
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    there is actually a 2'' difference in wheelbase and the burb is the shorter of the 2 at 129.5 whereas a longbed truck is 131.5. There will be issues with mounting a fuel tank (the burbs needs to be at the rear due to the second row footwell and I think that the frame bends up a lot sooner on the truck frame so it might take more than a 3'' B.L. to make it work (I don't know what the laws are like there but here in CA the body must be within 4'' including bushings of the frame /forums/images/graemlins/deal.gif.) Sounds like a lot of work, is there something wrong with said 'burb's frame? If nothing else, it would be a fun learning experience /forums/images/graemlins/smile.gif
  4. Ddragggon
    Apr 25, 2001
    2,657
    my bad... oh well. :-D
  5. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Are you thinking about using a 1 ton frame for added strengh?
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    Just beating ideas around for now... a first-hand account of a Burb body on a pickuo frame sure would be nice - if anybody's done it. /forums/images/graemlins/wink.gif
    My Burb's a C20... 4wd would be nice. The stronger frame couldn't hurt. I was thinking of 4x4ing the frame beforehand, and set it up with twin saddle-tanks AND the rear tank.
  7. Ddragggon
    Apr 25, 2001
    2,657
    the only problem with the saddle tanks, is where to put the filler nozels... on the pickups, there's the bedside, but on the suburban, there's a door, and if you're going to do heavy wheeling, then it'd not be a good idea to just stick it in the wheelwells, unless you had a hatch or protective covering of somesorts. hmm... now I must think about this, and consider doing it to mine...
    -Rich
  8. stylin6
    stylin6 Registered Member
    Apr 1, 2002
    40
    Kansas
    Have something similar.... 70 Suburban on a 77 Suburban 4X4 frame. Lots of work believe me! Used a 4 inch body lift and had to move the rear axle forward about 6 inches. If you've got a lot of time on the weekends, go for it. Otherwise, keep your sanity and start out with a solid, sound vehicle.
