Burb front end
Discussion in '1936-Present Suburban' started by m4, Feb 18, 2005.
  1. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Hello all, how difficult is it to replace upper and lower ball joints? This is on a 1991 4X4.I have a Haynes manual but the detail is lacking.
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    depends on your tool set.
    do you have :
    jack
    jack stands
    roter nut removal tool?
    ball joint wrench
    bfh?
    and some space if so no to to bad.
    need it on jack stands, pull wheel, caliper. spindle, axle.
    then remove your nuts and pull the knuckle.
    press (bfh) out the joints and press in your new ones
  3. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    I have everything but the press, which a friend has.
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    your good to go then . pretty strait forward....just use some comon sence as to which way they should be presed out.
  5. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah or you will be there a long time lol
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
