Burb hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by m4, Feb 27, 2005.
  1. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Hello all, do the hubs seperate from the rotors on a 1991 Suburban 4X4 ? Looks like the wheel studs need to bo pressed out to seperate?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Once the rotor/hub assembly is off the vehicle then the studs do need to be pressed out to separate the two pieces.
  3. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    but you dont need a press, after you hit the studs out, the rotor and hub will come apart after a few light hits
  4. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    cool, thanks I'll install new studs also.
