Burb of my dreams
Discussion in '1936-Present Suburban' started by txtough, Sep 2, 2003.
  1. txtough
    txtough Registered Member
    Aug 31, 2003
    39
    Lubbock Texas USA
    Just bought the burb of my dreams. 1990 v1500 with most of the goodies. I also bought a 77 3/4 ton LWB to steal parts from. I am starting the axle swaps on Wednesday and can't wait. This is my first post, but I have learned alot over the years reading CK5 articles and forums. I will have extra parts if someone is looking.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Good deal on your find of the burb and welcome /forums/images/graemlins/thumb.gif
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Welcome! Sounds like you are headed in the right direction already. Sounds like a sweet deal with the burb. Good luck with it!
    Kris
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Awesome! Keep us updated and post lots of pics! /forums/images/graemlins/thumb.gif
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    sounds great....I'll be the first, WHERE'S THE PICS???????
    Welcome aboard....in a few weeks the 'Burbs will take over this sight /forums/images/graemlins/thumb.gif
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Very cool, I'm kinda particular towards the '90 V1500 burb /forums/images/graemlins/laugh.gif (Although I'm in the process of making mine a V2500 /forums/images/graemlins/cool.gif)
    Thanks for supporting the site...it's a resource that no service manual can match (and trust me, I've got 'em all)
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    One of mine is a '90 V1500. VERY clean! It's now sporting a 14-bolt FF rear end and an 8-lug 10-bolt up front. Gears will soon be 4.56's at both ends. /forums/images/graemlins/thumb.gif Then a 4-inch lift and 35's will be added, just after the 454 goes under the hood. /forums/images/graemlins/cool.gif (I figure the engine swap will be MUCH easier before it's lifted). /forums/images/graemlins/wink.gif
    Welcome to the 'burb 'hood! /forums/images/graemlins/burb.gif
  8. txtough
    Aug 31, 2003
    39
    Lubbock Texas USA
    Started the transformation tonight. Lots of sweat and grease. I pulled the front axle on the pickup and started preparing it for the Burb. I talked to the people at Offroad Design. They are very nice and helpful, I ordered the rear shackle flip kit and the 4" front springs, swaybar disconnect, steering support and a few odds and ends to finish the install. I haven't worked with someone so knowledgeable is some time, they have all the answers.
    My question now is how do I I.D. the front axle that came in the burb? What is the difference in a Dana 44 and a corp. 10 bolt? Thanks for the warm welcome.
  9. heavy4x4
    Aug 28, 2002
    3,270
    Kinda hard if you don't have the two frontends to compare, but the 10 bolt has a much more round cover when comparing it to a Dana 44. One sure way to find out if it's a D44 is to look for "44" to be stamped in the housing to the bottom right of the diff cover. Also, on the top of my Dana 44, "D44-8F" is cast into the housing above where the pinion is.
    To save you some time though, if that's the original axle in the '90 burb, it's a 10 bolt.
  10. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I may be wrong, (It's happened ONCE before),but I think that in '90 only 10 bolts were used in the half tons. Also, check the technical section for Axle Identification. It is very helpful.
    Welcome aboard!
  11. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I have a 90 v20 burb that originally came with a 10b front
    & 14sf rear. It now has a d60 & 14ff.
  12. heavy4x4
    Aug 28, 2002
    3,270
    With a truck description like I see in your sig...you're going to have to get some pics up! /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif Did you swap in the 465 or did it have that as the factory option?
  13. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    The 350,465,241 was all factory. I just had nvrenuf swap in
    the 454 recently. I will try to get pictures up since it was
    recently painted.
  14. txtough
    Aug 31, 2003
    39
    Lubbock Texas USA
    Talked to the guys at Reider Ring Gear today and they positively ID my front axle off the ring gear part number it is a 10 bolt corp. Looks like you are all right again. I ordered a front and rear gear set and rebuild kits, some new hubs and seals and limited slips for both ends. Looks like I have some work cut out. I started cleaning the front axle to paint it, what a bunch of gunk it had accumulated over the past 25 years.
    I hoped someone could give me an idea about how a burb drives on 35" tires. Thirty-three inchers don't scare me because I have owned them but I hoped someone could share with me what 35's handle like. I am planning on 17 inch steel wheels with 315/70r17 tires.
  15. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
  16. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Handles great..............my dream 91 V2500 with 4L80E, etc....
  17. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I haven't had mine in the sand yet /forums/images/graemlins/frown.gif
    too many upgrades
