Burb sags on drivers side, need advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StampedeOfNorway, Mar 2, 2003.
  1. StampedeOfNorway
    StampedeOfNorway Registered Member
    Jan 2, 2003
    5
    Fredrikstad, NORWAY
    I've got an '88 Burb with 8 lug axles all around. The previous owner said that the "one side sagging" were due to a H.D. spring pack on the rear pass. side with 9 leafs, and just a standard 8 leaf pack on the drivers side. My Q is, should I remove one leaf from the 9'er pack, or should I add an ORD zero rate to the 8 pack? The truck does not sit level at all when I view it from either front or rear. I hope this is due to the lower height in the back. BTW my truck is not lifted, yet.
    Thanx in advance... /forums/images/graemlins/smile.gif
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    it prolly wont sit completly level unless you replace both rear packs, leaf springs are cheap at junkyards, atleast around here they are, If you got a U-pullit junkyard, just go find a set out of a 3/4ton burb, or maybe a pickup, Just make sure you get the same length springs as you already have, MY leafs from the J-yard cost 16 bucks apiece.
