Burb sags on drivers side, need advice
Discussion in '1936-Present Suburban' started by StampedeOfNorway, Mar 3, 2003.
  1. StampedeOfNorway
    StampedeOfNorway Registered Member
    Jan 2, 2003
    5
    Fredrikstad, NORWAY
    I've got an '88 Burb with 8 lug axles all around. The previous owner said that the "one side sagging" were due to a H.D. spring pack on the rear pass. side with 9 leafs, and just a standard 8 leaf pack on the drivers side. My Q is, should I remove one leaf from the 9'er pack, or should I add an ORD zero rate to the 8 pack? The truck does not sit level at all when I view it from either front or rear. I hope this is due to the lower height in the back. BTW my truck is not lifted, yet.
    Thanx in advance...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You can do it either way and it would be about the same. But if i were you, i'd just find a pair of new springs from a junkyard...they are really cheap /forums/images/graemlins/thumb.gif
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Or, by all of your new lift springs now. It's real easy to justify buying this stuff when something is broken.
  4. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    just one more thing to look into are the body mount bushings.i bought my burb cheap because i thought the springs were dead,turns out the bushings are gone and was causing it to sag bad on pass side.
    goodluck
  5. StampedeOfNorway
    Jan 2, 2003
    5
    Fredrikstad, NORWAY
    goodluck
    Dorky Q! /forums/images/graemlins/blush.gif How can I check if the bushings are gone? Can U see it with the bare eye??
    Thanx...
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yup, easily visible - you should see a rubber donut-shaped piece above and below the body mount - you'll understand once you take a look.
    There, should look like this except without the metal cylinder towards the top (unless it has a body lift) - thanks Muddysub for the use of your pic /forums/images/graemlins/wink.gif
  7. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    Sags on the drivers side... thats easy, Eat Less Burgers /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    mine sags too, because of crappy springs, bad body mount bushings, and whatnot. probably too many hamburgers for me too. /forums/images/graemlins/blush.gif
    -Rich
  8. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my 89 and my dads 90 both sag to the drivers rear corner.
    It's time to grab a tape and find out where the differences are.
    -Jeremy
  9. BanksBurban
    BanksBurban Registered Member
    Mar 23, 2002
    88
    New Jersey
    Mine sags on the left rear too. It's all stock, no lift.
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    yepp, my sub has sagged to the left rear for years now. maybe something wrong with the springs those years. i dunno. i'm gonna fix it one day when i'm not a poor colledge kid.
    i was just scrollin through this thread and glanced at that pic and thought "mine look like that" and then i was like "i painted my ac lines too" "wait a minuite, thats mine!!" i'm a slow one. /forums/images/graemlins/crazy.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Your too much muddy!
    Mine saggs to the left also. Even after the new springs I think its because all the extra weight is on that side. IE. the spare, which by its self weighs quite a bit. Put a lone driver in there and there is another 200 plus pounds. Just a thought.
