burban being dumb
Discussion in '1936-Present Suburban' started by 82K5_6.5L, Jun 26, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    my friend has a 90 Burban and its being dumb! he will drive down the road and it will make some weird grinding/tinking noise when not accelerating.. i thought it might be a bad u-joint in the rear.. or could it be the front? not sure.. should he replace them front and rear and see what happens? anybody have this problem? and also what kind of t-case is it? thanx 4 the help
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    sometimes mine does that. i dont know what it is but it gets kinda annoying. i think it might be something in the trans or a bad mounst in that area. /forums/images/graemlins/thinking.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Replace the rear u-joints for good measure.
    Also, if it's 4 wheel drive, leave the front u-joints alone - they aren't spinning when in 2wd. BUT, if it's 4wd, definitely swap out the auto hubs for some manual ones.
    The combo of new joints in the rear and manual locking hubs should cure the most common grinding/ticking noises these trucks experience. If it still does it, time to dive deeper into the rearend or t-case or tranny or etc.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    That's a NP 241 transfer case, just clean it up and look for the round tag on the back....
  5. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    well ok, recently he had his rearend rebuilt because he blew it up.. so i dont think its in the diff, he put all new gears in, but we havent changed the u-joints, but he does have manual hubs, do u think we should take them out, clean them and grease it back up?
    thanx! /forums/images/graemlins/wink.gif
  6. heavy4x4
    Aug 28, 2002
    3,270
    Nah, leave the manual hubs alone until after you change out the rear u-joints.
    Is there vibration at speeds above, say, 45mph? If not, don't go swapping the u-joints without checking them first. Grab the driveshaft and shake it up and down, left and right, back and forth. If there's no play in the u-joints, don't change them. If there is play, swap them out for new ones, and you should be good to go. /forums/images/graemlins/thumb.gif
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    flex plate, right Muddy?
  8. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/thinking.gif Not a bad thought /forums/images/graemlins/thinking.gif
  9. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    flexplates rattle wen yur accelerating, wen yur jus coasting along they dont make noise. if they get really bad they'll rattle wen you shift in 2nd, if theyre about to fly apart into a thousand pieces they'll rattle going into 3rd too. trust me i kno.
  10. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    hey kinda sounds dumb, what are the flex plates? it usually does it when he doesnt have his foot on the gas and when its slowing down..?
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  12. muddysub
    Jun 23, 2001
    10,451
    489
    the flexplate goes between the touque converter and the crankshaft. and holds the ring gear for the starter.
  13. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Muddy that is your experience. My flexplate would rattle at idle and quiet down under load after stepping on the gas. They are all different. /forums/images/graemlins/eek.gif
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    still sounds like its falling apart, at the least coming loose from either the crank or the torque converter. I'd get under there and take a look. Pull the inspection cover and look /forums/images/graemlins/thumb.gif
  15. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    hmmm.. i understand a little more now! well if it is that, is it easy to replace, or fix it? could it just be loose?
    thanx for the pic!
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If you get under there and find that its loose, i'd be for looking at it closely to see why i came loose, typically cracks cause it to come loose.
    But to change one (i've change one 4 times in 3 months time on my burb) remove starter, unbolt bellhousing from motor, unbolt both driveshafts from t-case, unbolt t-case crossmember and slide the tranny/t-case combo back enough to get to the bolts /forums/images/graemlins/thumb.gif
  17. muddysub
    Jun 23, 2001
    10,451
    489
    if it is cracked the inside of the inspection cover will be grooved and youll be able to see where it has been rubbing
  18. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Do you still want to get the stub shaft for your rig? If you wanted to come out in the burb, I can listen to it when you are out here, and maybe help figure out what's up. Jimmyjack just replaced his recently due to noises like that. If he needs a new flexplate, we are getting pretty good at unbolting trannys/case/etc lately. Let me know
    Erich
