'burban tank in a pickup?
Discussion in 'The Garage' started by pismorat, Mar 19, 2004.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    \'burban tank in a pickup?
    I have a buddy with a bunch of old suburban tanks in his back yard (mostly 73-90 body style). Would one of these fit where my stock spare tire mount is between the frame rails? And how would you go about setting up the fuel pickup, mounts, and lines for it? Any suggestions?? /forums/images/graemlins/truck.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: \'burban tank in a pickup?
    a burb tank will fit into a longbed but not a short bed. the short bed is just too short. the blazer tank is better for the short bed, because it fits /forums/images/graemlins/waytogo.gif
    you would need to take the cross members from the blazer/sub and put them into the truck. then just extend you fuel lines to the tank. you will need to use the proper sending unit for the tank. for the fill tube, you can make it like stock with a door on the pass side, or you can put the fill tube in the bed of the truck, or where ever you want.
    i have looked to put a burb tank into my long bed and the tank will clear the rear axle by like 3 or 4". on the burb i think its more like 8".
  3. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I have a Suburban tank in my K30 dually. In addition to the 2 saddle tanks.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive been thinking about doing that, how did you plum it?
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    WOW, a $400 fill up /forums/images/graemlins/doah.gif /forums/images/graemlins/waytogo.gif
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    NAAA, i just filled up the other day, i was pretty low, and it ran me $65.00. /forums/images/graemlins/yikes.gif
  7. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    How much is gas there, $1.00 a gallon? It's $1.599 & climbing here!
  8. azblazor
    May 5, 2001
    1,953
    One switch shifts the valve and sender between the rear tank or either of the saddle tanks. The second switch shifts between either of the saddle tanks.
  9. azblazor
    May 5, 2001
    1,953
    [/ QUOTE ] Well its a diesel, so that helps - it gets 16+ MPG pretty easily. If I take the saddles and the main down to a comfortable level - it takes about about 65 gallons to top off. That does leave 2-3 gallons in each tank for a margin of error. That gives me a pretty easy 1200 mile range on the highway. Lets just say your time behind the wheel is not limited by the vehicles fuel capacity.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    must be cool to have 1.60 gallon gas, its 180 here maybe a little more, i havent looked for a coupel days
    burban tank should fit any wheelbase, the frame length changed in between axles not after the rear axle
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    By my calculations the shortbed is 5.75" shorter than a longbed in the axle-to-end-of-frame dimension. /forums/images/graemlins/deal.gif
    http://brochures.slosh.com/1973/gmcpscc11.jpg
  12. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    There's a difference in the length behind the axle.
    Several years ago, I swapped a TBI 350 from an '89 Burb into my '78 K20. I considered taking the tank from the Burb to put in my truck too. If I remember right, there was a difference in the measurements between the frame rails, an the truck did not have the room for the tank. I didn't want to cut my frame, so I decided not to use it.
  13. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    somebody over at the 1947 to 1998 chevy & gmc message board has done this and has a write up with pics....
    DW
