Burbanzilla is Biotech
Discussion in '1936-Present Suburban' started by Ddragggon, Mar 23, 2004.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    I'm preparing to do an SM465 swap into the 73 K20, since I lunched the NP205 on my TH350, and I figgure the TH350 won't stand up to the abuse the 454 can dish out... With luck, I'll get some time in the next few weeks to actually do the swap, and have enough money laying around to make it happen. All I need right now is a flywheel ($180) Clutch kit ($130) and pilot bearing ($3). That, and a weekend to drop the TH350/205, and install the SM465/205 in it's place.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Good luck, hope it is 'all that easy'
    If it were mine, nothing would fit right, and the very last bolt would break causing a complete dissassembly to fix.
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Damn, $180 for the flywheel?
    I will need one soon, Iguess I should try my luck at PNP next time I go.
    /forums/images/graemlins/doah.gif
  4. Ddragggon
    Apr 25, 2001
    2,657
    I'm going to see if I can get a random chevy flywheel from the pick A part, in hopes of using it as a core for a remanufactured flywheel from Autozone... remanufactured flywheel costs $60, but the core charge is $105... New flywheels cost $180.
    Dragged the tranny/t-case combo down to a turbo wash/self serve carwash, and blasted the hell out of it. unfortunately, it was getting dark and cold, and as such the grease re-solidified into an impenetrable shell. I'll be trying again tomorrow afternoon while it's still warm outside, and with luck, I'll get the remainder off, so I can paint it in time for my scheduled install saturday.
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Try using some Greased Lighting to get that grease off. It worked well for me.
    Does any one have any 205 parts laying around? I need a rear output flange and a front output shaft bearing/seal reatainer. (You know the little aluminum piece that's held on by 4 bolts)
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Where do you get that Greased Lighting stuff? I've heard its really good for getting oil spots/stains off of concrete/pavement.
  7. chvyhs
    Feb 12, 2001
    1,469
    I got it from my mom in a car cleaning kit. I'll see if I can find out from her.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Cool thanks /forums/images/graemlins/thumb.gif
  9. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    AutoZone....
  10. dirtyburb
    dirtyburb Registered Member
    Apr 3, 2004
    16
    dragon want to sell the turbo 350 NP205 adapter
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    clutch kit comes with a pilot bearing, if not i have one you can have.
    in near you as well.
    Grant
