Burgler Proofing A Topless Blazer
Discussion in 'The Garage' started by 4wheelin4Jesus, Apr 30, 2005.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    Does anyone have any tips, tricks, or advice on how to burgler proof your rig. In the summer, the top will be off 24-7. I was wondering what i could do to deter theft.
    thanks,
    I was looking more to keep from having my rig stolen. I am going to weld a locked consol for anything loose. As for the a kill switch, ive never used one. Does it go straight on the battery, or can you relocate it. Sorry for the lack of info above.
    thanks
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Shark with lazers, dummy!
    Hard to do. Best way? No stereo, the club, and a kill switch.
    Orrrrr.....
    Automated robot napalm spiders with burglar sensitive seismic sensors and cheese-whiz dispensers...
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Lift It High!!!!!! :d
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Theft of the truck or the stuff in the truck?
    To keep the truck from getting stolen use kill switches (1 or multiple). On my Jeep I use a Kryptonite cable wrapped around the seat bracket with a BIG Master Lock.
    To help deter people from stealing the K5 I smash it on rocks. :D I also keep anything I don't want stolen locked up in the toolbox I built, in the console, and I take the stereo face plate off and hide it or take it with me.
    Harley
  5. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    shock sensitive alarm..........big mean dog chained in the back.
  6. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i have a VIPER motion sencer alarm they dont even have to touch it to set it off. $180
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Have faith and maybe no one will take your stuff :surepal: .
    Like they said above, are you trying to protect the truck or what's in it??
    Be a little more specific please and maybe someone can help you.
  8. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Club or Auto lock.
    Alarm.
    Starter kill.
    Ignition kill.
    Fuel pump kill.
  10. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    i added more info to my question,
    thanks
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Normally the kill switch goes on the 12V feed to the distributor. If you have fuel injection, cutting power to the fuel pump also works (or do both). The switches can be located wherever you want them to be. Cutting off the battery requires a big switch which would be hard to locate discreetly.
    These measures DETER theft, but don't PREVENT it. A mechanically inclined thief can wire the ignition or the pump directly if they have some time alone with the vehicle. In most cases, though, they will give up and move to an easier target, like an Escalade :D
  12. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    With my TPI'd 71 I've got the ability,via a removable switch,to enable the VATS (Vehicle Anti-Theft System) programming in the ECM.
    I plug in my switch turn it to a pregrogrammed number and the VATS is enabled.Another turn of the switch and the VATS is disabled.
    The eng will still crank over but it will never start.
  13. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    5.13s and an ORD Doubler......
    When you park, shift it into compound low and lock the levers in position so they can't be moved.
    Any thief trying to make a getaway will be doing so at about 1.5MPH.....slow enough that you can walk right up to him with your favorite "street justice" implement (taser, baseball bat, 9mm) and say:
    "Looks like you're about to have a bad day!!!"
    :cool1:
  14. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    Add thief kill to that list and it is complete!
    Kill switches "inside" the locked console box will be an additional deterrent!
    LE style shotgun mount...empty of course...that'll make 'em go "hmmmm".
    Bryan
  15. r_pogo
    r_pogo Registered Member
    Mar 15, 2005
    23
    Azrizona
    From Arizona, the truck theft capital of the world...
    The steering wheel people Grant have a "No-wheel Security Ssytem". See the current Jeg's catalog, page 210. It costs $109.00.. For more details see the Grant web site.
    This is an adapter that mounts between the steering wheel an the steering column. A key is inserted into the adapter, you move a lever, and the steering wheel comes completely off. A metal cap is then placed where the steering wheel went, the lever moved back and the key removed. You take the steering wheel with you (they sell a nice carry bag) or maybe it can be locked up in some sort of a heavy storage box welded to the floor with a Harley lock on it.
    Hard to steal the truck without a steering wheel. And if the wheel is removed with the front wheels locked all the way to one side it makes towing a bit more difficult. Just for fun I plan on finding an old used steering wheel and modify it so it has a bracket which covers the ignition switch and attaches to the Grant cap and just spins when you try to turn it. Sort of keeps the crooks from even THINKING about trying to break into the Grant adapter. And its good for a laugh.
    An alarm system will only work with the battery connected and the first thing the crooks do is disconnect the battery or punch a hole in it from below to drain it (they bring a spare battery along with them). With no battery power they then open the hood and disconnect the alarm wiring. So for an alarm to work you need a backup battery hidden somewhere and a pager to tell you that you truck is in the process of being stolen. Crooks search for the backup battery as soon as the alarm trips if they think nobody will notice the alarm for the few seconds it takes to find the backup battery. But by the time they find the backup battery the pager would have sounded so you can grab your .45
    Once in and with the alarm disabled crooks then look for the kill switch. I am planning a homemade special kill circuit. This will be a toggle switch easy to find under the dash as a bait switch, plus a small 12 position rotary switch out of the way under the seat. I spin the rotary switch when leaving the truck. When starting I count a number of clicks for the rotary switch position to power a relay to power the ignition and fuel pump. If the ignition is turned on and the rotary switch is in any other position than the one start position, or if the bait toggle switch has been moved, a fuse blows in line with the relay. No ignition and no fuel. Thereafter the fuse has to be replaced for the system to start. Will get to this as time permits.
    Anyway, a neighbor's truck had an alarm, Club, and TWO kill switches, parked in the carport 20 feet from the bedroom window. They heard the truck start and by the time they got to the front door it was was GONE, on the way to Nogales. Battery acid and the old battery were on the ground. Pieces of wire insulation were also found on the ground where the crooks made jumpers around the kill switch they couldn't immediatly find.
    In short plan on RELENTLESS DETERMINATION to steal your ride.
  16. American84K5
    American84K5 1/2 ton status
    Jan 22, 2005
    294
    Midland, TX
    haha id take my top off and leave it.. n e wayz who would wanna steal my truck :D
  17. dyeager535
    26,978
    One of the steering column collars will prevent a majority of theft. Easiest way to steal a GM with this type of column is to break the plastic section where the key is (opposite side though), the collars cover that section. Doesn't stop someone from hotwiring, but if the internal steering wheel lock works, they can't *drive* it until they get around that issue.
  18. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    locks and alarms only keep honest thieves away. I like the idea of not giving them anything decent to take.
  19. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I like gregs idea :o
  20. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
