Burning bushings out of springs...
Discussion in 'The Garage' started by sled_dog, Jul 18, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Will it adversly affect the springs? I mean if I just take a torch to the bushings and let them burn away till they aren't in my way anymore. The bushings in my 52s are stubborn little bastages.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i wouldent think that the rubber would get hot enought to do anything bad to the spring
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would use mapp gas next time I do it . Mine weren't rusty ( AZ ) but wouldn't come out . We torched them with propane , took a little while but once hot enough burned away quickly .
    Then it was just drive them out ( outer sleeve ) with air chisel .
    And it still took all day to do all my rear spring bushings :wink1:
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    drilling and air chisel is the way to go...takes about 10 minutes per eye... and then you dont have nastly molten and charred rubber everywhere ....
    personal experience!
    it wont get hot enough to take the spring temper out...but why chance it
    cam
  5. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    i usually burn em out! the bushing usally pops out before anything gets real hot :angry1:
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    eh, the are all chewed up from drilling and chiseling and still won't come out. Tiny chunks at a time. I'm sure I spent 45 minutes per side and got no where. Been a long time since I messed with them.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    if you do it and dont have a b tank setup definetly ue mapp gas, it burns hotter than propane and weill greatly speed up the process.
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    ill prob try burning them next time i need to do some just to try it. i used a ball joint tool to push the small metal sleeve out. then i was able to chunk the rest of the rubber out with a large flathead screwdriver. the part that took the longest was getting the metal sleeve out of the eye with the air chisel. took about 20 mins per bushing to remove and install a new one.
