Burning Oil; Where To Start
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by clubba68, May 22, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    My truck has been rapidly burning oil. Any ideas of where to start? It's not leaking a drop. Burned about 1 qt. in 120 miles of freeway driving.
    Thanks,
    Andrew
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    yikes... that seems pretty excessive...
    I say rip out the motor and put in a stroker 383... I know you can get 400hp 450lb/ft for under 2k /forums/images/graemlins/thumb.gif
  3. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Two first things to check would be valves and rings. run a compression check on all your cylinders and record the values. After you check each one, squirt a little oil into the cylinder through the spark plug hole and check compression again. If you have a bad ring (or more than one), the compression will be low, but will increase a bit when you add the oil (oil on top of the piston helps the ring seal). If it is a bad valve adding the oil should have no effect.
    A couple quick visual checks. Pull your PCV valve after driving and see if it is dripping oil. Maybe you dropped a valve cover baffle. Are you running aftermarket valve covers? Do they have a baffle? (Mine don't and I suck a ton of oil through the PCV at highway speeds)
    Check your plus - are you sure it's burning? If it is your plugs will be a crusty black. If they're fine, check for oil in the coolant, you may have blown a head gasket.
    All I can think of off the top of my head. Good luck
    C.
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Doesn't that thing have a stroked motor in it?
  5. clubba68
    Dec 6, 2002
    1,511
    Yes, it is a 383 stroked in there. Yes I do have aftermarket valve covers. Yes I will check them. And thank you for your help. I'll let you know how it turns out.
    Thanks,
    Andrew
