burning oil
Discussion in 'The Garage' started by lamberthkp, Feb 23, 2006.
  1. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i recently put a new cam kit in my blazer and have been burning oil on the right side out the exh. the truck never smoked before until i changed the springs. im thinking maybe i messed up one of the VALVE STEM SEALS on that side or put it on wrong or something and am going to replace them this weekend . anyone else got an idea or am i right . thanks ,Keenan
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Being a lazy man, I'd pull the plugs on that side yet to see if one (or more) of them is not like the others.
  3. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    OK, this is a quesiton, but isn't there only two ways of oil to get into the combusiton chamber to smoke out the tail pipe, spring guides or rings? If that is true, it seems pretty unlikely that changing your cam coincided with a ring on a piston deciding not to seal.
  4. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    well i just pulled the plugs and non seem to have burned any oil , actually i pulled both sides they are all clean they still look brand new. i wonder if it will stop when i get my new tbi chip for engine mods. it only smokes when i idle after few min and i think thats the only time i use oil about 1/2 to 1qt a week.
    when driving down the road my oil pressure is about 6to8 lbs lower when driving down the road . i norm. run 36-40 now im 30-33.
    any ideas!
  5. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    i did drive to charlotte NC from jville NC this weekend and back and did not use a drop. but now that im back in town driving slow and stoping and going its use'n it again.
  6. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    So, would you say that during lower vacuum operation it doesn't chew oil, but at higher vacuum it does?
  7. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    im gunna put the chip in and see what happens , should be here this week or next
