burning out brakes
Discussion in '1982-Present GM Diesel' started by airborne808, May 5, 2003.
  1. airborne808
    airborne808 Registered Member
    Mar 8, 2003
    9
    Hawaii
    I'm new to four-wheeling and need some help.
    This weekend, I took my M1009 Blazer up a mountain (3000 ft elevation) to my wifes company cabin.
    I've never four-wheeled a CUCV (even in the Army) but the beast performed FLAWLESSLY all the way up. My wife rented a Mountaineer and it performed just as good, if not better...anyway...The road up is very, very treacherous, next to steep cliffs. It was fun, but also very nerve racking.
    Then came the ride down......
    I was in 4 high but still needed to ride the brakes. I tried to shift to 4 low, but the shifter wouldn't go...
    Halfway down, I smelled the brakes burning, but because of the treachery of the road, I couldn't take my foot off the brakes..
    By the time we were at the end of this road, I had very little braking power and the brake light was on.
    I stopped to let it cool down and within a couple of minutes things were almost back to normal.
    Need some help because we want to go back up in a couple of months but I don't want to go through the same thing again....and I must admit....4 wheeling can be very addicting.
    Jeff
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    For steep decents you should be in low range and let that 6.2 do the majority of the braking for you. You must be stopped and in neutral or park to shift the transfer case into low range. Trying to shift from high range to low range while moving can cause damage to the transfer case.
    Basically what happened was you began to boil the brake fluid from having to ride the brakes for so long. You were lucky not to lose the brakes entirely.
    Next time shift the T-case into 4-low, then put the gearshift into L-1 and let it idle down...your brakes will thank you and you will live to enjoy another day of wheeling!/forums/images/graemlins/thumb.gif
    BTW...if you want to put that mountaineer to shame, take them both into some major rocks...LOL
    Rene
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I should add that after boiling the brake fluid like you did that a thorough inspection of all the seals in the brake system should be done. Check carefully for leaks anywhere in the system, pay close attention to the calipers up front and the wheel cylinders in the rear.
    I would not be surprised to hear that some parts need to be replaced after that. The braking system was not designed to ever operate with the fluid that hot.
    There was actually a video of a couple descending the Lion's back in Moab Utah in a blazer. They successfully went up and came back down on the brakes all the way. The brakes were very hot and they decided that the guys girlfriend would drive up and then down because it was so much fun. Up was no problem, but on the second descent the brakes boiled and failed.../forums/images/graemlins/eek.gif
    The footage is terrifying as they came down completely out of control and wrecked badly at the bottom. I'm pretty sure they survived...only by the grace of God I'm sure.
    Rene
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    They must have been real hot to boil Silicone brake fluid! Although silicone won't absorb moisture like regular brake fluid, moisture (rain?) may have entered the master cylinder at some time. I would bleed some (and add some new) fluid from the calipers/cylinders. Also inspect the rotors for bluing and heat cracks.
    I used to work at Volvo garage near Mt Washington. I remember a guy that took his (fully loaded) wagon down the "autoroad", dragged the brakes the entire way! Volvos have legendary brakes (4whl disc starting in 1969) but those babies where toast /forums/images/graemlins/eek.gif
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Where could we acquire this footage?
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I use 4lo as soon as I leave pavement... and its good up to 50km/h with 4.10's and 33's.
    Were you trying 4lo while moving? Most t-cases won't do a graceful 4hi/4lo shift while moving - if at all. You should not be attempting this shift on a steep descent anyways... you cross through the neutral position on the t-case and you suddenly lose any hold-back the engine was providing /forums/images/graemlins/eek.gif
  7. airborne808
    Mar 8, 2003
    9
    Hawaii
    Thanks for the input everyone. I'm taking the beast to my mechanic in a few days for its physical. Drove it a little bit today and the brakes seem to be working okay, but sqeeking a bit when I come to a stop.
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I saw the footage on one of those "shocking video" type shows a few years ago. I can't recall the name of the show though/forums/images/graemlins/blush.gif
    Rene
  9. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I remember that video. Wasn't it a green colored Blazer, coming down the side at full speed and landing on it's top? It's amazing anyone survived that.
    Casey
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I think there was more than one Blazer coming down the lion's back video. The one I remember the Blazer was brown, veered to the drivers right just before the bottom and stuffed the front end right into the ground at the bottom.
    I'm showing my age here but I think the show was "That's incedible"...which goes back quite a ways.
    rene
  11. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    They've shown it on a bunch of shows. I know I've seen it. They ALMOST made is straight down, but at the bottom they went off to the right and crashed. Everybody lived, but I think one of the people got messed up a bit. It was pretty spectactular.
  12. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Thats the one I saw, just the other day on another show the lady that was driving the blazer did it again in a jeep, but made it down ok.
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    Actually I saw that footage too and it wasn't the brakes, the girl decided to kick it in neutral and by the time the guy noticed and told her to slow down it was too fast and brakes wouldn't do anything.
    Never go down riding your brakes and always have it in gear, lowest you can so you don't need the brakes.
