Burning Smell and Schreeching In Clutch Area
Discussion in 'The Garage' started by DuallyK5, May 27, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    I just got a another 88 k5 with a 8 inch lift and 38.5 super swamper boggers. I dropped a 350sb into it from another blazer i had. Now i was just driving home and 1 street from my house when i took a turn i started to hear a schreeching noise, pretty loud. Now my clutch seems to be actuating fine and not slipping at all. What could this be. Sometimes is stops and then if i push the clutch pedal in it can make it sound more screechyer or stop it but is fluckuates. Can someone please help me figure out whats wrong with it. I had a sm465 4speed with granny low. Thanks. Oh yeah and it doesnt smell like a clutch burting almost like a plastic kind smell but im pretty sure there is a bearing in the crank and not the buishing u can get.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    throwout bearing or the input retainer is broken
  3. DuallyK5
    Apr 6, 2006
    32
    New Jersey
    ok
    Thats what i thought it would be but im pretty sure its just the bearing since it stops every now and then. It only happen a strett from my house witch is good. Is it bad to drive it like that like will it wear anything out or break anything by over heating it?
  4. readymix
    May 30, 2004
    6,706
    26
    Depends on what it is. I would get it fixed either way.
  5. DuallyK5
    Apr 6, 2006
    32
    New Jersey
    ok
    Yeah I drove not to far so i could pic my car up. It seems that the clutch was pretty stiff when i first got it compared to my buddies blazer but it got a bit stiffer now and i got a new bearing from advanced auto parts but i had a quick question. Part of it is plastic is that alright like will it hold up cause i dont know how throwout bearing work completly could someone explain it to me?
  6. readymix
    May 30, 2004
    6,706
    26
    Well the retainer will look like this. Be sure it is not broken.
    This is a typical throwout bearing installed on the fork and retainer.
    If it does not look like this something is wrong. Keep in mind that the second pic I posted is not form a SM465. I have no isea what it is......but it will look essentially the same.
    Now the throwout bearing pushes on the forks of the pressure plate and releases the pressure between the clutch disk and the flywheel. You will see it when you tear it apart. Be sure that you use a clutch alignment tool when you put it back together
  7. readymix
    May 30, 2004
    6,706
    26
    Here you can see an alignment tool in the very center. Also note hte wear on the pressure plate fingers. his is typical and does not necessarily indicate a problem.
  8. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    Is the bellhousing tight to the transmission? And the bellhousing to the block?
  9. DuallyK5
    Apr 6, 2006
    32
    New Jersey
    yeah
    Yeah the bellhousing is tight on the block and the trans. Im pulling it apart i think tommrow.
