burnt A/C-heater fuse
Discussion in 'The Garage' started by TheEmissary, Dec 24, 2005.
  1. TheEmissary
    TheEmissary Registered Member
    Apr 15, 2000
    63
    Houston, Texas
    I am constantly burning up my A/C-heater fuse to which the blower motor is dead. I do not know what is causing this although I have checked the blower motor relay and resistor assembly.
    When checking the fuse after inserting a fresh one, the fuse is hot on one side to which I have went through 20+ 20 amp fuses and most recently, 25 amp fuses. Right now, I cannot use the A/C and heater blower motor anymore to which I am considering wiring a bypass to the car battery.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    um, it blows because it is drawing too much current
    try unplugging the blower motor, if it doesn't blow with the blower motor unplugged, I would replace the motor
  3. dyeager535
    26,978
    Does this setup use a connector somewhere inline from the fuse panel to the heater?
    I know on the cars GM used a wiring plug that had terminals that were too small. The wire that drew the most juice always seems to melt the connector.
  4. dave_90_blazer
    Jan 1, 2004
    688
    good question, I think I'll go look at mine to see if I see one
