burping a 2.2 head
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by MIKE_MN, Jun 13, 2001.
  1. MIKE_MN
    MIKE_MN Registered Member
    Apr 11, 2001
    13
    MINNESOTA
    I KNOW THIS IS THE WRONG FORUM.BUT I AM SURE ALL THE WRENCHHEADS ON THIS BOARD WORK ON OTHER TRUCKS. I AM REPLACING A CRACKED 2.2 HEAD AND WAS TOLD TO BURP THE HEAD(REMOVE ALL THE AIR(REPLACE WITH ANTIFREEZE) FROM THE HEAD. DO I JUST FILL UP THE RADIATOR OR DO I HAVE TO DO SOMETHING SPECIAL.
    I KNOW STEVE CHIN WILL PUT IN A GOOD SUGGESTION. SO THANKS IN ADVANCE. THANKS FOR THE HELP EVERYONE.
    MIKE IN MINNESOTA 72 BLAZER K/5 350 465 TRANNY, 205 T-CASE WITH A FOUR INCH LIFT.
    MIKE FROM MINNESOTA 72 CHEVY BLAZER
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    air usually gets traped below the thermostat. you can fill the radiator up and wait till the water slowly fills the gallaries in the block/heads/etc or remove the water thermostat housing, fill to the rim and replace it. check the water level in the rad once your engine is warm(thermostat open).
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    It also helps to agitate the cooling system by repeatedly squeezing the hoses. I like to jack the car or truck up so that the radiator is also located higher than the engine to help any air pockets leave. A lot of guys will drill a couple of 1/8"-3/16" holes in their thermostats to aid in air escaping.
