Burst Pipe in a rental, should I try PEX, Zurn???
Discussion in 'The Lounge' started by uglytruk, Apr 13, 2007.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    So I went to Lowe's, and their line of ZURN is way overpriced!
    So a qwik check of eBay shows a similar crimper for $70 less, ($105 vs $173+tx) but of course I'll check for overpriced SH. Valves at Lowe's are $9. Simple single fittings $2-3-4 each. What a rip-off! :eek1:
    Here's some pix... BTW, they're both made overseas, read CHINA... :doah:
    Should I use the solid rings? Or raised pincher style?
    PEXcaliber Multi-Head PEX Crimp Crimper Crimping Tool
    FREE 5-year ReplacementItem number: 150112070803[​IMG][​IMG][​IMG]You are signed in Watch this item in My eBay
    [​IMG][​IMG][​IMG][​IMG][​IMG] var ss0ImageUrls = descImageUrls = [[ 'http://www.ssb4.net/users/12553/crimppic1.jpg' ]]; var hostedimageSRc= 'http://www.ssb4.net/users/12553/crimppic1.jpg';writeHostedImage(); [​IMG]View larger picture[​IMG]
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    So whats the deal with the over priced tool kit? I would have just got some new fittings and sweated in a new line. Or a another fix would have been a couple copper to PCV fittings and replace the line PCV.........
  3. uglytruk
    Oct 24, 2004
    1,329
    I've sweated enuff copper... fire,smell, all inside a cabinet.
    Time for a new system, and I've got a BIG job coming up. Checked the price of copper lately? Just gotta' find that stuff cheaper...
    ...and the prob isn't the disconnected joint, it burst in the crawl space. What a great idea to thread plastic thru the 6" opening. I shoveled sand and removed huge rocks to discover that the leak is at the other side. No access, couldn't even get a pix. LOL
    Oh yeah, if ya look carefully, you can see the PVC I already used from the kitchen sink to the batroom sink. Bathtub is next...
    This hot water tank is under the counter. Compared to the top post, this is "normal". The shut-off valve was in the corner. I moved it way off to the right. accesible now.
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    WTF, where in the hell do you live???If I were to guess it would be lower slobovia. Run a focking garden hose instead of what you have going on in those pics...
    Uhh Ok that sounded bad , didn't mean anything, just where are you??? And why is your plumbing so focked up???Sorry for your misfortune...
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I could have fixed the problem for $32.78.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Idda whipped out my 5 gallon plumbing bucket and cheeeezed,,,,errr uhhh I mean correctly fixed the problem for cheeze, I mean free...:rotfl:
  7. uglytruk
    Oct 24, 2004
    1,329
    Where am I? Lower Monglia...
    Seriously, this prop is in the country, 40lbs of well pressure.
    Copper? It blows up. Just ask my brother.
    Or look at this pix of a 2" TYPE K line that rotted from the inside, buried in 6" of concrete. Maybe the garden hose ain't soooo bad...
    Sorry, can't find the pix of the 2" line... next time
  8. uglytruk
    Oct 24, 2004
    1,329
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Screw that, just let me drop some napalm and expend some flashbangs. Forget the cheese:D
