bushing fiasco, need measurement help
Discussion in 'The Garage' started by stoney126, Jul 27, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    Ok before I decide to just blow my crewcab up, and boy let me tell im close to it. I need bushings for my rear springs. It is a 1989 gmc crewcab 1 ton solid axle 4x4. Now I burned out the rubber bushing the outer sleeve is still there, which I have been told to leave on by just about everybody.
    My options for bushing are 1 3/4, 1 1/2, and 1 3/8. Now I measured the outer sleave bushing it measures Inside diameter 1 19/32 or 1 5/8 I cant seem to get it very precise. I am in serious need of help this lift is taking waaaaayyyy to freakin long and about to call it quits.
    Now I have some bushing that are the wrong size at least I think so, it measures 1 11/16 which is to big for it
    Seriously though any help would be greatly appreciated
    My rear shackles measure in at 1 3/8 so at least i got that to go on.
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Hey Robert. 1 11/16" is the metric bushings which will fit if you remove those sleeves. The only other choices at least from ORD is 1.5 and 1.75 which aren't even close to the metrics. Remove the sleeves and those should slide right in. Make sure all the spring eyes are the same some of the 56's have two different sizes on each end. DON'T buy the greaseable poly bushings from ORD for the metric size. They don't have the grooves in them for the grease to flow. I just went through all of this for my 56's too.
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    From the link Dremu gave you:
    Quote from MTBLAZER89
    From me: ROMOVE THE DAMN OUTER BUSHING SLEEVES!!! :D :D :D
  5. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    measured both eyes and there the same size. Now as far as removing the outer sleeve I have been told by my teacher, a machinest and The owner of a 4x4 shop not to remove those outer sleeves say ut F's things up:confused:.Why would they say that ? is there any reason for it? How do I remove em? Oh ya these are energy suspension if that matters.
  6. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    how do i remove the sleeves?
  7. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    a big ass hammer!!! sorry im no help and realy tired.
  8. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I usualy take an air hammer with a chessel end, and drive it out with the chisel end riding along the gap where the wrap around of the leaf spring ends. You could do this with just a BFH hamer and a hand held chisel as well.
    Another way to do it is if you can cave the sleeve inwards, until you are able to drive it out with a long punch.
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    I have the exact same truck and I ordered the 1.7 metric bushings, and yes remove your sleeves.
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    They say not to remove them because they think you are putting stock bushings in. If you are using uerathane you MUST remove the sleeve to install the bushings. I cut mine with a sawzall by sliding the blade in the slit where the spring eye meets the flat of the spring. Then use a punch to fold the bushing in on itself.
    Ira
  11. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    right on guys, many thanks.:D
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
