bushing help
Discussion in 'The Garage' started by 82_k5, Aug 22, 2004.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I have an 82 fullsize that i have been fixing up. I built some bumpers for it and dropped in a low milage 350. One of the last things that i'm gonna do to it for a while is put new bushings on the front leaf springs and sway bar. After cutting, heating, and hammering i finally got the old bushings out. Do you guys have any advise on getting the new ones in? Particularly the ones on the fixed hangers on front with metal sleeves. They just won't go in!! /forums/images/graemlins/1zhelp.gif
  2. Alaska K-5
    Alaska K-5 Registered Member
    Mar 10, 2003
    54
    Alaska
    Coat the outside of the bushing with a little light chassis grease, and use a C-clamp to press them in...
  3. 82_k5
    Oct 3, 2003
    94
    thanks for the advice i'll give it a try
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    ive had good luck running a file or die grinder in the spring eye to clean up the surface of rust.
