bushing on --- top off
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by rrent, Apr 1, 2003.
  1. rrent
    rrent 1/2 ton status
    Jun 10, 2001
    174
    Round Rock, Texas
    Greetings all - I got the body bushings on -- only had to go back and make one adjustment -- had to add a couple of shims to get the drivers door to close the way I wanted it. I think a couple of shims must have fallen out or rusted away a year or two back -- thats when the door got harder to get closed. I pulled the top off and am ready to start the process to give it a cheap and easy weekend paint job.
    I've just about decided on white - possibly with black bed liner material from the lower body line down......
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Keep it yellow,mine was the same yellow, I just put Hummer yellow on it and it's very close to the original color...well sort of...
  3. SHINTON
    SHINTON 1/2 ton status
    Dec 26, 2001
    148
    Kernersville, NC
    My dad painted his S-10 with Herculiner from the lower door and down and then painted OVER it with the regular color. It gives it that 'factory undercoat' look. I am thinking about doing the same thing, only issue is rust will eventually come back and I don't want to clean that stuff off when repairing.
    I have to admit baby poop is the ugliest color they did imho, and I would switch too! That yellow hummer color looks nice, white will be the easiest since it shows almost zero dents or imperfections!
    I am hoping to put my new poly body mounts on soon, next 3 weeks! I may have to shoot you some emails when I do if I run into snags!
    Sam
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    putting the under coat on and painting over it sounds like a great ideal...didn't think about that, I'm going to paint the lower half of the truck with Line-x and follow the line from the front to back, even that 1" inch wide strip over the wheels
  5. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    There are several spray on liners that can be color matched rather than painting it. The color would be all the way through and won't flake off. I don't know if there are any roll on liners that can be color matched.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I was at the Seattle auto show a few years back and looked at a spray on bedliner.I think it was a Heculiner vender.Anyway he said nowadays you cazn have any color you want,color matching your truck isn't a problem,it just costs ALOT more that a black bedliner.
  7. mountainibis
    mountainibis Registered Member
    Jan 29, 2003
    75
    Morrisville, NC
    I looked into putting spray-on liner for the lower rear panels of my pick-up with a color match. Everywhere I went told me that the colors would match at first, but then would fade after hitting sun, salt, possum, and anything else your tires decide to kick up.
  8. rrent
    Jun 10, 2001
    174
    Round Rock, Texas
    I've got Herculiner on my brush guard - been there for about 2 years with one second coat a few months ago. It fades to a demi-gloss real quick, but I have had no problems with it coming off. I figured semi-gloss on the bottom might work.
    Been going back and forth on the yellow, white... no yellow, okay white..... and on it goes.
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    yellow...
