Bushing Part # needed
Discussion in 'The Garage' started by Hossbaby50, Dec 29, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need the part number for bushing kits for 52" rear springs. I would prefer Daystar number if possible. Thanks
    Harley
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    from here http://www.rockymountainsusp.com/W_poly_GM.htm#Spring & Shackle
    67-72
    K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD KG02006 $36
    67-87 K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD
    with 1-1/2" frame shackle bushings
    KG02006 $36
    73-87 K5 Blazer, Suburban, Pickup, 1/2, 3/4, 1 Ton 2&4WD
    with 1-3/8" frame shackle bushings
    KG02008 $34
    73-87
    K5 Blazer, Suburban, Pickup, 3/4, 1 Ton 2&4WD
    with 1-3/4" frame shackle bushings w/3950 lb. rating
    KG02016 $50
    73-87 K5 Blazer, Suburban, Pickup, 3/4, 1 Ton 2&4WD
    with 1-3/4" frame shackle bushings w/3600-3500 lb. rating
    KG02007 $40
    81-87 Suburban, Pickup, 3/4, 1 Ton 4WD with 1-1/2" frame
    KG02012 $47
    81-87 Suburban, Pickup, 3/4, 1 Ton 4WD with 1-3/8" frame
    KG02013 $47
    81-87 Suburban, Pickup, 3/4, 1 Ton 2&4WD with 1-3/8" frame
    shackle bushings w/2600-3500 lb. rating
    KG02011 $40
