Bushing questions
Discussion in 'OffRoad Design' started by afroman006, May 11, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I built a custom engine crossmember on my truck to use 1 1/2" bushings. I was wondering if ORD had any bushings available that were softer than their urethane suspension ones. I built my motor mounts out of 2" 1/4 wall round tube stuck on some 2" 1/4 wall square tube. They will be for a 6.2L diesel.
    Also, what are the bushing sizes for a set or 56" rear springs off a 84 chevy 3/4 ton? How about a set of 63" rears from a 91 C/K series 1 ton dually? I looked on the website and it said the 1 tons are unpredictable but I'm just wondering. I am definately going to measure before ordering anything though, the last time I didnt and ended up getting the wrong sized bushings twice before finally getting the right ones.
    Also, are the urethane transmission mounts the same height as factory ones? I am shooting for the flattest belly possible and am going to build a custom crossmember for it. Thanks.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We might be able to special order some softer compound bushings but I'm not sure you could tell a big difference. If you want to try, we could take a look at it.
    For the 56's, you'll probably have a 1.75 front eye and 1.5" eyes on the rear of the spring. The IFS truck springs should have about a 1.7" eye front and rear.
    Urethane replacement t-case mounts should be very close to the same height as stock, at least new stock. They tend to shrink as they get older.
  3. afroman006
    Aug 21, 2002
    2,876
    Well I already ordered the bushings so its all good. It turns out I already had a bag of 1.5" ones layin around from something else but oh well. You are right about the 3/4 ton springs, they were indeed 1.75 and 1.5. I decided to wait on ordering the 63" bushings so I can make sure I get the right ones. Is the 1.7ish one the metric size?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, technically they're 1.705 but the spring eye is probably closer to 1.7".
