Bushing Removal
Discussion in 'The Garage' started by nvrenuf, Dec 8, 2004.
  1. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    What's the best way to remove the upper/rear shackle bushing for the front spring? I have seen them melted out with a torch but I don't have one. Is the bushing pressed in or what?
    BTW - I'm working with a bare frame.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine was two pieces the just pulled out. Only had to use a pair of pliers
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The ones I've changed have been real easy to change... (other than header removal) but they've been driven recently when replaced. The easiest thing to do is to beat out the sleeve with a hammer and then pull the rubber out with a pair of channel-locks.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Oh ok, I don't know why but I was thinking it was bonded in there.
    As always, you guys are great help! THANKS!!
  5. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    Just did the busings to all four springs. You can either use a pair of big pliers, or vise grips that look like they fit around a soda can ( I bought a pair at HomeDepot). The bushings are two piece, with an inner sleeve. This didn't work on all bushings. If if doesn't, place the spring pack in a table vise, take a drill with 1/4" bit and start drilling through the bushing. This may take a while, but it works. Once you get most of the bushing drilled out, take a metal shank to the lip of the bushing sleeve and bang out with a BFH.
    The plier/vise grips work if using on poly bushings. The drill method works on OEM rubber bushings. Note, if OEM rubber bushing, there is also an outer metal sleeve that either needs to be cut with a Saw-zall or pryed out with a chisel. I used a small diameter chisel (1" in width), aslo bought at HomeDepot, and hammered out. This will take some time, as you need to split the outer sleeve. Pretty straight forward. This was my first time doing this and although took some time to do all the spring ends, new bushings were definately needed!
    After bushings are out, use a wire brush to clean out the spring eyes. Use a bunch of grease and new bushings should slide in. You may need the table vise the press bushings in completely
  6. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    I used a air chisel, came right out.
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    take a 6" 3/8's inch extension and place it inside the bushing, tap it though the entire way and the inner sleeve will come out, then you can remove the two peice bushing working your way around the ouside diameter with a screwdriver
