Bushings
Discussion in 'Parts & Trucks Wanted' started by jck54x4, Jul 14, 2005.
  1. jck54x4
    jck54x4 1/2 ton status
    Aug 18, 2004
    104
    Houston, Texas
    I have a set of 6" Skyjacker Softride springs for the front of my 88 burb. I am missing a set of rear bushings dont know what happened to them :doah: . Anybody have an extra set they want to get rid of.
  2. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I have some brand new Energy Suspension bushings that are for the rear of the front springs and for the shackle bushings that go through the frame. They take the stock size bolt, so if you run or want to run ORD shackles up front they won't work due to the larger bolt that is used with the ORD shackles. The reason I don't have the bushings for the front of the front springs is because I used them and went with ORD shackles.
    They are red in color.
    $20 plus the ride? (which shouldn't be much)
