Busted Rear Shock Mount
Discussion in 'The Garage' started by offroadcowboy, Nov 4, 2004.
  1. offroadcowboy
    offroadcowboy 1/2 ton status
    Jan 29, 2004
    171
    Wittman,Arizona
    Anyone have any suggetions on how to fix a busted rear drivers side shock mount.Mine sheared at the rivets and I need some suggetions on how to either fix it or fab up a replacement.Thanks
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Grind it smooth and weld it. If you don't have a welder a local welding shop should be able to hook you up cheap
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There is no good way to get a welder in there to weld it up. Mine has broken the same way. I removed my rear shocks and have had them out for 2 years. I am going to fab up some new mounts sometime soon. The bounce is kind of annoying. I also need the shocks to help control body sway now that I have more lift then I used to.
    Harley
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run one single center mounted shock from the pinion to the x-member. It stopped the bounce, gets a bit wild with big bumps but it rides smooth (1 crappy shock). I also don't have any more wheel travel issues.h
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Sometimes you see that bracket in the LMC catalog. I ended up welding a washer to the inside of mine to reinforce it up on the shock mount where mine broke. You can get in there but it is a PITA. Can't you just bolt it back on?
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Look at the Missouri Offroad outfitters at his website this guy hass a bad azz setup going on, it looks like it just bolts on.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes i used that it rocks!!!!!! plus he is a way cool guy and helped me out alot i would absoulty recomend his stuff /forums/images/graemlins/peace.gif I looed at mine, it looks like you might be able to get some bolts through it it but it might be a real PITA to do /forums/images/graemlins/dunno.gif
  8. offroadcowboy
    Jan 29, 2004
    171
    Wittman,Arizona
    Hey thanks all for the suggestions .I think i am gonna fab up some kind of mount to last me for a while then go with the missori off road kit or make one of my own. /forums/images/graemlins/yikes.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif
    here is a crappy drawing of where it broke the jagged lines being the shear point
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'm thinking it wouldn't be that hard to fab up something out of thick angle iron for now. MOO is a good shop. He fabbed up some lower bolt on shock mounts for my Corp14ff after I cut my stock ones off prematurely. I eventually will go with his over the top truss for the rear. In fact, he might be able to fab up an upper shock mount for you.
  10. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    If you want, I'll take mine off and send it to you. Just cover shipping. /forums/images/graemlins/thumb.gif
