busted rear window cable - help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by creampuff90k5, Nov 1, 2002.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    A few days ago, the cable between the rear power window motor and regulator broke. No big deal right? Well unfortunately, the window was DOWN! How the heck do I get the window back up again so I can replace the cable? Thanks.
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    OOH. What part of the cable broke? You could probably shear back the plastic part and turn it with some vise grips. Replacing is pretty easy.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    take the panel off, and remove the cable from the motor and see if its broken on the motor end, or at the regulator, if its at the motor, cut the case back and try to turn it up, if its at the regulator, take it to the glass shop.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  4. RockaFella
    RockaFella Registered Member
    Sep 12, 2002
    63
    South Carolina, Rockhill
    For a Temporary Fix Take apart The Back (Tailgate Pice Facing Torward Front of Blazer) And unhook it all push up your glass and put it back togeter b/c leaving it down sucks in exhaust and rain its gotta be horrible to have it down...
  5. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    tried all of that already...
    I've had the blazer since brand new in 1989, so I'm no stranger to tailgate problems, but this one really has me stumped.
    Already tried the drill/vise grips/stripping down the cable idea. It didn;t work and in fact, some more of the cable snapped off. This leads me to believe that "stuck" portion of the cable is on the regulator side, which is blocked by the glass.
  6. rogerwilco71
    Sep 22, 2002
    179
    Central-Cal
    Re: tried all of that already...
    You should be able to un-bolt the rails that the window rides on (to get to the regulator area). The part going into the regulator is the same as the motor, and try to turn it to move the rails 1/2 way up and re-attach the window (not more to be able to close the tailgate). Close and roll up the tailgate (turn cable while its shut). OR run to the dealer and replace that $30-35 cableright away.
  7. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    GOT IT!!!
    Rogerwilco71, you're exactly right. I discovered those four bolts at the bottom of the glass and was wondering if that would work, then read your reply. Wrenching in those tight quarters is no picnic, though!! Dealer will have new cable in on Monday...
  8. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    remove the covering and expose the cable and get your cordless drill and attach to the cable and you will have /forums/images/graemlins/thumb.gifa temp fix to keep out the cold. worked for me /forums/images/graemlins/rolleyes.gif
  9. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    Re: GOT IT!!!
    Mine got stuck the same way And I wound up drilling small holes over the bolts on the bottom of the window so I could get a rachet on them, then the window will lift up with your hand.
    Matt
