Butcher Jones - questions
Discussion in 'The Garage' started by AZ79K5Project, Mar 22, 2007.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I ran a local trail (Butcher Jones) with a buddy today. The thing flexed pretty well considering blocks still on the back. The shackle flip is on the garage floor.
    I had serious tire rub on the left front wheel well - rear edge of front well only and slight rub on the right side wheel well. I wouldn't think I'd have to trim with 33's.
    On the drive back, the thing pulled real bad to the left on braking and then it went away. All new brakes and new MC.
    I got it back in the driveway and noticed that the thing wasn't sitting level. I measured it and found that the right rear sat 1 1/2 inches lower then the left rear.
    Any ideas?
  2. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Besides a bent spring or a stuck shackle: frame flex/tweak? I know every time I'm out there my entire truck moans and groans.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    mine seems to do weird things on the way out from there all the time too, Usually clears up and drives fine alittle while later...
    that is actually a pretty mild area to "wheel" at considering where the guys have taken me in the past.:crazy: :D
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Time to break out the sawzall. 33's will rub under hard flexing. Rubbing isn't terrible as long as there isn't any lips for the tires to catch on. I rub a decent amount with my 37's and 4" lift but I have cut all the lips back where it only rubs on the flat parts of the inner fenders.
    Harley
  5. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I was a little concerned for that very reason. I'll be cutting... This was the first test of the truck.
    The carb hiccuped on one of the steeper hills going up. I tried to bounce over a bump without too much right foot. It sputtered a little but stayed running.
    That truck got a little warm inside with the top on.
    This was a fun little hill - a little damage to the exhaust that used to extend out by about 1/2 inch:
    Overall I was pretty happy with the performance and flex of it of my truck. We were both testing the trrucks a little. He's heading up to Moab with his J@@P.
    The best part of the trip for my five year old was getting to throw rocks in the water. Good times.
