Butt sagg?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kenaik5, Mar 23, 2007.
  1. kenaik5
    kenaik5 Registered Member
    Oct 25, 2005
    19
    oregon
    My 72 has a 4" lift with blocks in the rear. Is this kind of lift causing my rear end to sit lower than the front? Should i go with a spring lift, or will it always sit like this? Any help appreciated. Thanks:confused:
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    You need extra lift in the back just to be level. Mine has 6 inch tuff country ez rides up front so 6 inches of lift in front
    Back has 4 inch ORD shackle flip, 3 inch tuff country ez ride springs and ORD super shackles which gave it 1 1/2 to 2 inches lift. so close to 9 inches of lift in back. It is just level.
    2 inches extra in rear is about right for normal no cage heavy bumpers etc.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Your stock springs are sagging. Common problem. Replace them with good used or get some lift springs and it will go away. It is not unusual for the rear to need an extra inch or so of lift to sit level.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I use a zero rate in the back to keep it level.
  5. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    Thats how my truck ended up so high. I had some sag in the rear, fixed it and then i had sag in the front, fixed it, then i had sag in the rear again. Finally have it fairly level 11" later :haha:
  6. duallyjams
    duallyjams 1/2 ton status
    Feb 17, 2007
    167
    Deale Md
    looks like 11" and 42's are just right :laugh:
  7. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I [​IMG] saggy butt!
    That just sounds wrong, but my 72 has a bit of saggy butt and I kind of like the look. It goes with the psydo-stock look I have. SBG (saggy butt syndrome) is pretty common. They had a slight bit of SBG from the factory. 1"-2" more lift in the back than the front is usually the answer.
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup...the Blazer's butt is way heavier than a Pick-up and most spring manufactures make the lift springs off a pick-ups weight specs not a Blazer..
    I run 4" front and 5.5" rear.
