buying 87 jimmy diesel
Discussion in 'The Garage' started by K5-newf, Jul 13, 2006.
  1. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    hey im lookin at buying a 87 jimmy diesel i was just wondering wat areas and problems should i look for before i buy it.
    i know to check the tail pan and the floor in front of the rear pessenger seats.
    one thing i noticed is that the front tries are a size smaller then the back i was told that u can not put it in to 4x4 like this because 1 set of wheels have to work harder then the other 2 im not sure if this is true so anyones info is greatly appreciated
    sry about the noob questions
  2. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I want the Diesel me jelous...... can't help you on wheels but it makes sense. I would prefer a diesel if it is running right they get around 22 mpg on highway from what I am told.
  3. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    Correct If the tires are off a bit. A larger tire covers more ground in one revolution. So if the back tires are larger they would be pushing the front tires.
  4. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    IIRC, if they are like an inch or half different it wouldnt hurt much to use 4x4 a little IE test it and stuff like that. Same with if you have different gearing inthe front and rear. The gears can have a little bit of difference like .03 or .3 one of the two lol.
