Buying a cheap K5....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevy4x4, Jan 2, 2001.
  1. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Ok, I have read hundreds of magazine articles and posts on various sites (mostly ck5.com) about what things to look for and watch out for when buying a used 4x4. But what are the things that sould be taken into concideration when buying a 4x4(blazer) for around 1.5-3k? What should be expected from a 2000 dollard blazer? Obviously the engine, trany, t case and axles have to be in ok condition and the body rust doesn't matter too much as long as its still on the blazer.
    [​IMG]K5[​IMG]
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Make sure the frame isn't cracked where the steering box bolts up at. Have a friend move the steering wheel back and forth and see if the box moves around alot.
    '73 K5
    Chevy good...Ford bad
  3. chevy4x4
    Apr 27, 2000
    1,454
    Yeah...so I guess almost everything is the same......I was hopeing for a little different answer.......
    [​IMG]K5[​IMG]
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    it all depends what you you plan to do with it over the next few years.
    Knife.
    knife.coloradok5.com
  5. chevy4x4
    Apr 27, 2000
    1,454
    Lifted up 6 inches, put 38s under it, add corp 14 bolt rear and dana 44/60 up front, modify the engine a bit, strip the interior for weight reduction, driving it daily and mudding and trail riding on the week ends.
    [​IMG]K5[​IMG]
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Since you're going to replace most of the drivetrain anyway, I'd look for something with a very nice body and interior. That way it will at least look good while you're building it! [​IMG]
