Buying a new Engine. Any tips !
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by frank8808, Nov 1, 2002.
  1. frank8808
    frank8808 Registered Member
    Jul 20, 2002
    15
    San Diego CA, USA
    I have a 91 Blazer Silverado 4X4 With 33's and a 2 1/2" suspension lift with 456 gears . I am going to replace the Engine and I am leaning towards buying a GM creat motor. I tow a trailer 22' when we go to the dessert and need more power. Help!! I don't want to buy a new truck. /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    IMLAO you got right, stick with a GM creat motor. they cost a lil more but you get what you pay for.
    befor i knew better i had a loacal shop build and install a new motor for me and i still regret it 3 years later.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Do you have a local engine builder ??? Those guys can usely beat the big places prices and offer just as good of a warrentie, if not better. Also lots of local engine builders will build you a 383 stroker to your specks, built more for your app., the big chain places all build a basic engine. I'd go for one built for more low end torque, and around 9 to 1 compression. With the custom built engine you can get a cam more for low end torque also, without haveing to do a cam swap later costing you more money and possibley voiding your warrentie. Just something to think about.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Didn't they warrentie thier work ????
  5. beater74
    May 29, 2001
    1,749
    atlanta
    they shut down two weeks after they gave me back my rig. and 7 months later the harmonic balancer broke off distroying the crank /forums/images/graemlins/angryfire.gifand my 18 month warr. wasn't worth a crap.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    That sucks, sorry to hear about it. I've delt with local engine places and have had good luck. Had a 454 in a 77 Monte Carlo that was a very good deal for me at the time. Engine was still running strong 4 years later when I sold the car, and I beat the $hit out of that car almost daily. (I was in my early 20's when I had it.)
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you want more power.You might check out either of these 2 crates desighed for your 91 with TBI
    sdpc2000.com TBI 350 HO
    sdpc2000 TBI 350 Vortec HO
    Both of these engines should work with the stock chip in the computer. But I dont think you willl get the claimed HP with the stock TBI and chip.
    I would suguest modifing your TBI also.
    These guys can help:
    turbocity.com
    I use a lot of their stuff and it works pretty much as claimed.
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Why not build your own?
    Get a 4-block main, some vortec heads, any dual plane intake and you've got a good engine. 350 rebuild kits cost as little as $155 (new pistons, rings, all bearings, cam, plugs, gaskets, lifters, chain, etc.) Buy a few books, buy a few tools, and just do it.
    -- Mike
  9. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I went and got a gm crate engine and put it in my /forums/images/graemlins/k5.gif Ill tell you this its the best thing I had done after all the looking in to a rebuild of another block (I had a 6cyl before)I did change the cam however.all I can say is its awsome.I spent 1400 for everything,had to get new motor mounts and a balancer too. /forums/images/graemlins/usaflag.gif
  10. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Call me at work monday. I can get you fixed up one way or another...
    Jim
  11. frank8808
    Jul 20, 2002
    15
    San Diego CA, USA
    Jim
    Where do work? I see your are in El cajon I'm in Santee.
    Thanks,
    Frank
